Winch ATV into bed
dan1911
Fairbanks, Alaska
Ok so i know this has been discussed on many places on the interwebs, and i have done it successfully with my old G*C.
On the 04 models, they had some pretty hefty anchor points in the front of the bed, then I went to a truck stop and bought a heavy duty ratchet load bar (used to secure cargo in semi truck trailers) and put it between the two anchor points to create some counter pressure. I used some coated cable and some big rings to attach between the two anchor points, and attached the winch directly to the cable and pulled the atv up.
I know some of you are thinking "just drive it up"
And yes, typically I do not have an issue doing so. I know the "back it up to a ditch" thing, and I have decently long, bi fold ramps.
My issue is.... the lady of the house. Sometimes she loads/unloads when I am not home and when we had the G*C it wasnt an issue since she just winched it up... still have an intact window.
The anchor points on the 4th gens seems pretty flimsy and I doubt they can hold the King Quad weight being winched up.
Any thoughts on how to make or secure an anchor point that would allow that much force to be winched in the bed?
kg93
AZ
uhmm drill some holes in the bed that match up with a winch and put some steel bracing under the bed.
Reactions: U&A
D
dan1911
Fairbanks, Alaska
sorry, i guess i failed to explain where the winch was lol.
The winch is on the ATV. Very valid option though, I would prefer not to buy another winch if I can avoid it though.
Im wanting to see if there is a solution where I can attach the ATV winch to the truck that wouldnt damage anything
Neumie
MN
5.7 8a
Angle iron across front bed rail, secured at each side with a strong tie down anchor in middle for winch. Co-workers use this technique. I drive up.
D
dan1911
Fairbanks, Alaska
Are they just securing the angle iron to the factory anchor points in the bed, and im assuming the angle iron is with one side on top of the bed (duh) and the other on the side between the bed and cab?
D
dan1911
Fairbanks, Alaska
These are the photos of what i had in the old truck, very sturdy and worked great
Neumie
MN
5.7 8a
I will take a picture if any are on the lot tomorrow.
D
dan1911
Fairbanks, Alaska
Awesome, thanks! I went to a few different places up here in Fairbanks... But it's slim pickings up here lol
Neumie
MN
5.7 8a
[/url]image by darren_neuman, on Flickr[/IMG]
This is similar to what I described but has the winch to load equipment without a winch. Same concept though--and it could be prettier that's for sure.
Internet is so hard! lol
D
dan1911
Fairbanks, Alaska
Image link is broken, maybe it's just me but i cant see it on my phone or computer
Csanders1992
I probably pull your bed off and build some bracing on the side that meets the cab. And have an anchor point come through the center. Most of will be hidden this way, but it will take a lot more work
D
dan1911
Fairbanks, Alaska
Lol could definitely be prettier!
Pretty good concept for sure. If this is a local guy you took a pic of, can you ask how he attached to the stake pocket? Seems he has the plate bracing on the bottom of the winch and im sure that provides quite a bit of support, so i would need to figure out a workaround from that.
Uggghhh.... why couldnt they just put nice beefy anchor points from the factory:angry94:
D
dan1911
Fairbanks, Alaska
Initially I thinking maybe it was possible to attach some cables to the frame rails underneath (one on each side), and run them through a small eyelet hole inside the bed where the two cables would meet. I have no idea how this would work or if the force of the cables from the rails would start to shred the metal eyelet
U&A
Michigan
2016 3500 SRW
6.4 HEMI
this. and when you dont what the winch there make a cover plate that utilizes the bolt holes. heck you could even put some wing nuts on it for easy on and off.
U&A
Michigan
2016 3500 SRW
6.4 HEMI
or hook a chain for one side to the other on the front tie down points and pull it up the ramps with the winch that is on the front of the 4wheeler.
D
dan1911
Fairbanks, Alaska
If you look at the pics i posted earlier on my G*C thats exactly what I did, but i had the load bar to provide some counter pressure. The issue with this is, the anchor points in the the 4th gen are just bent at a 90* and have a single spot weld holding them onto some flimsy sheet metal. My old setup worked flawlessly, even in -30* snowy weather lol but I dont think its a safe option since the anchor points are pretty weak
kg93
AZ
honestly idk, you might be over thinking this, the king quad weighs what? 750ish full? not that much going up a ramp rolling rather then dragging dead weight. I say try it the way you had it on the other truck and see what happens hahaha
D
dan1911
Fairbanks, Alaska
You probably have a point there... the lady says that all time hahaha.
Yea the KQ is about 750 and Im around 170-80, and I have 8ft ramps. Just looking for a more secure way to get up, but yes, im likely over thinking it lol
DannyMK2
Long Island, NY
2015 Power Wagon
agreed. you could even rig up a snatch block in the middle and hook the winch cable back to the quad.
You're probably good. The way I'm thinking is the long ramps lessen the force tie downs are seeing when loading by winch - they are not seeing the total weight of the quad and passenger. When you're cruising around with the quad in the back and go over a bridge or cattle guard, you may rise up in your seat for a sec, there is upward force greater than 1g for a small period of time. Or if you take a corner quickly, tie down points on one side of the rig resist all the force. Those tie down points can see 1g, maybe 2g under normal conditions or more while travelling and haven't deformed in my experience.
