Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 3rd Gen : 2002 - 2008 > Towing & Hauling
Towing & Hauling
'03 Ram 1500 Trailer Wiring Electrical Gremlins
This is a discussion on '03 Ram 1500 Trailer Wiring Electrical Gremlins within the Towing & Hauling forums, part of the 3rd Gen : 2002 - 2008 category!
Hey guys, need some help here. I've researched online for this problem and even tried to troubleshoot it myself, but ...
Like Tree1Likes
  • 1 Post By RonJon '06
Reply
Old 05-19-2016, 01:54 PM   #1 (permalink)
Rambling's Avatar
Ram Year: 2003
Engine: Magnum 4.7
Default '03 Ram 1500 Trailer Wiring Electrical Gremlins
Hey guys, need some help here. I've researched online for this problem and even tried to troubleshoot it myself, but no luck. The problem I'm having is I don't have power for my left turn/brake light at my 7-way factory trailer plug in on my '03 Ram 1500 QC. I have an adaptor that plugs into the 7-way that coverts it to 6 or 4 pin. This adaptor also has little lights on it that indicate that the left turn/right turn, brake, and running lights are working correctly. When I plugged it in yesterday it was indicating I had no power to the left turn/brake lights at my 7-way plug in. I checked the wiring at the back where it plugs in and all seems fine.
I then removed my adaptor and confirmed the 7-way trailer plug was not getting power to that specific pin using my test light. The right turn/brake works, as well as the running lights. But no left turn/brake light. All fuses for the trailer 7-way plug are ok, and not blown. I even tested the left turn/brake fuse for the 7-way trailer plug at the fuse block (#46), using my test light and it showed power to both test points on the fuse. And I also hear the relay going when the left blinker is on. So what I'd like to know is what gives..? I've tried to locate the problem but I don't know where to go from here. I read that the relays can be the problem. But from what I understand they seem to be integrated into the IPM, (Integrated Power Module). So if that is the issue, from what I've read you need to replace the whole IPM. Which I'd really like to avoid, cause I've heard they aren't cheap to replace. So if anyone can offer me any insight on what to do or try that would be great.
Sponsored Ad
Register to remove this ad.
Rambling is offline   Reply With Quote
Old 05-21-2016, 12:23 PM   #2 (permalink)
Rambling's Avatar
Ram Year: 2003
Engine: Magnum 4.7
Default
Nobody have any insight on this..? Any help would be greatly appreciated.
Old 05-21-2016, 12:34 PM   #3 (permalink)
derekp's Avatar
Ram Year: 2007
Engine: 1990 5.9 Cummins
Default
My dad had something similar happen on his ford. It was all integrated together and was like $800 to replace. So what I did was I tapped into the tail light wires and ran it to the hitch plug. You just have to find out which one is the correct wire for turn/brake. Does the same thing just uses a different route to get there. I can't really tell what the problem is on your truck without being there myself but it sounds like you're on the right track. If all else fails you could try that.
derekp is offline   Reply With Quote
Old 05-21-2016, 04:28 PM   #4 (permalink)
RonJon '06's Avatar
Ram Year: 2006, 1985
Engine: 5.7, 360
Default
I had a similar problem with my 06, TIPM was bad. They sell an actual harness that plugs into the truck tail lights then down to the 7pin, 50 bucks but cheaper than buying a new TIPM.
derekp likes this.
__________________
2006 | 1500 | MCSB | 4x4 | Built 5.7L Hemi
Forged Internals, Edge 2600, HD Trans cooler, JBA Shorties
1985 | W350 | RCLB | 360 | Dana 44/60, Firestone Ride-Rite Airbags
RonJon '06 is offline   Reply With Quote
Old 05-21-2016, 09:15 PM   #5 (permalink)
Rambling's Avatar
Ram Year: 2003
Engine: Magnum 4.7
I agree with that RonJon. So I think I'll probably end up going that route if I can't figure it out. Cheaper then buying a new IPM as you stated. Do you know where I could buy this harness for the 7pin, (Link)..?
Old 05-22-2016, 12:34 AM   #6 (permalink)
RonJon '06's Avatar
Engine: 5.7, 360
Default
I bought mine from the dealer but it was just like this. I plugged it into the truck tail lights then had to splice into the wires that were dead coming from the TIPM.
2003 Dodge Ram Pickup Custom Fit Vehicle Wiring - Curt
__________________
Old 06-06-2016, 12:53 PM   #7 (permalink)
Rambling's Avatar
Ram Year: 2003
Engine: Magnum 4.7
Just thought I'd give everyone a little update here. After doing some more diagnosis, and getting my mechanic to double check my theory. It is indeed the left trailer turn/brake relay that was bad. The left/right turn relays both make two distinctively different sounds when their on. Plus my mechanic actually had a used fuse box laying around that was the same as mine. So he swapped my fuse box out for his and my trailer lights all worked. So I was right to suspect that based on the issues I was having and the the information I found out online.
Now, just to compare prices with everyone. A new replacement fuse box (IPM), would of cost me $950 from Dodge. Wow..!! And a used one was $440 with shipping. Ouch.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Electrical Gremlins crzylee Audio & Electronics 4 10-06-2014 09:52 AM
Electrical gremlins and issues (and identify things) winstontj General Discussion 2 05-14-2014 08:47 PM
Electrical wiring question Oilbelcher Audio & Electronics 0 05-10-2014 05:46 PM
Wiring connectors, DIY trailer wiring harnesses 0212353 For Sale 12 03-07-2013 09:03 AM
Electrical Gremlins GO AWAY!!!!! Bigtman07 Tech Info 44 12-17-2011 06:36 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
