Camper
ralaubach
CA
2007 Ram QC
07 hemi qc 2wd 3.92 gear. Looking at campers around the 5000lb mark. I live in WI so I'm not planning on going into any mountains any time soon. I know the rating of the truck will handle it, but looking for some real world experience from you guys.
Is my peddle going to be mashed to the floor the whole time?
Is cruise control even an option?
What to expect for MPG?
Thanks guys
justin13703
MD
It'll be fine. No your foot won't be mashed to the floor, it'll pull 5k just fine with a 5.7 and 3.92s
R
ralaubach
CA
2007 Ram QC
Correct me if I'm wrong, but OD should stay off when towing?
justin13703
MD
Probably wouldn't hurt, but I'd just put it in tow mode and leave it at that
fastgti
Augusta GA
5.7. hemi
This is pulling a loaded 30ft travel trailer which weighs 5400 lbs empty. We are traveling from Augusta ga to Colorado and hitting a lot of hills and traffic. A/C is on because of the dogs and our son. We are in haul mode most of the time. I have a 2006 ram 1500 4 inch fabtech lift and 35 inch nittos on stock 20in wheels. I am so have a weight distribution anti sway hitch on and a brake controller. If you have specific questions just let me know and I can answer from my opinion.
R
ralaubach
CA
2007 Ram QC
At cruise, what kind of RPM/speed were you around?
airdrianify99
I have mega cab, but I would expect 8-12 mpg. Just make sure to watch temps on inclines
fastgti
Augusta GA
5.7. hemi
Just saw this post sorry. At Cruze, strait flat road I would see about 14
fastgti
Augusta GA
5.7. hemi
I have mega cab, but I would expect 8-12 mpg. Just make sure to watch temps on inclines[emoji106]
Yes temps did skyrocket on me. Had to keep rpms way down and speed as well. Got scared a few times truck was going to blow up
airdrianify99
Does 1500 with MDS have aux trans oil cooler
fastgti
Augusta GA
5.7. hemi
Mds is that where 4 cylinder shut down?
justin13703
MD
Yes mds is where 4 cylinders shut off and yes an 07 with the hemi and an auto does have a trans cooler.
VLG6963
