Draw-Tite Activator Brake Controller Install
nickmacgregor
Purchase an activator 5100 trailer brake controller for my 2006 Ram 1500 SWB.. should this be plug and play or is there more wiring involved? If so, does anybody have a step by step on the wiring.
Thanks
89gtcs
it depends. Do you have factory 4-pin or 7-pin harness already?
Trenton
its plug and play if you have the blue empty female plug up by the emergency brake against the fire wall
KansasBob
Only Plug and play if you have the Trailer Tow Option, and not just the factory flat 4 connector.
There is a plug for the brake controller under the dash either way, so you have your hot feed to your brake controller, and the needed brake lite signal, but if all you have is the flat 4 connector, the brake signal wire and hot wire dead end in a multi pin connector behind the front wheel well. You have to tap into the wire and install wiring to the back of the truck yourself. I think there is a factory "kit" for like $80, but I just ran my own wires.
