Let's see your hitch!!!
Budakane
Northern VA
345ci Hemi
What tow setup are you running? Post up a pic of your tow setup, gear ratio, and max tow rating. Aaaand Go!!
Budakane
Budakane
Northern VA
345ci Hemi
I'll start with mine;
Hitch: Reese Towpower 3 Ball w hook.
1/8-3000lbs, 2-6000lbs, 2 5/16-10000lbs, Hook-10000lbs
Gears: 4:56 (Formerly 3:92)
Haven't towed more than 7500lbs but always good to be prepared.
Esgordon123
Dothan AL
I leave my weight distribution hitch in. It will cause some one to think twice about parking so close to the rear end of my truck ImageUploadedByTapatalk1420571288.483082.jpg
Harley Harrold
USAF Ret. 36+ years service
Mississippi
5.7L HEMI
Factory class IV receiver hitch, 3.92 gears, 2wd, max tow 9,100lbs.
Harley Harrold
Mississippi
5.7L HEMI
I leave my weight distribution hitch in. It will cause some one to think twice about parking so close to the rear end of my truck View attachment 42655
I bet the first time you walk around the back of your truck and clip that hitch you will be wanting to leave it off until needed.
Searay245se
BrookPark Ohio
2015 Power Wagon Laramie
I use to leave mine in all the time too till i was in a hurry and forgot about it and ran right into it almost breaking my leg.
Budakane
Budakane
Northern VA
345ci Hemi
With my setup there is 1 great advantage, ppl are afraid to drive near my bumper, so no tail gating!!!
Esgordon123
Dothan AL
Never happened I know it's there.
Esgordon123
Dothan AL
I am very aware of it. It saved the bumper. A Camry rear ended me when I first got my tundra. No damage to the truck but the Camry had to be towed away.
Searay245se
BrookPark Ohio
Not on my truck but this is what my setup is for towing my travel trailer.If I hit that hunk of iron with my leg,my leg will be the loser in that fight.
Esgordon123
Dothan AL
Yes that's what mine is. Weight distribution hitch.
