Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 3rd Gen : 2002 - 2008 > Towing & Hauling
Towing & Hauling
Tires for towing?
This is a discussion on Tires for towing? within the Towing & Hauling forums, part of the 3rd Gen : 2002 - 2008 category!
So I am just checking to make sure my tires are good. Currently running toyo open country at2. The size ...
Like Tree1Likes
  • 1 Post By sbarron
Reply
Old 08-06-2016, 10:50 AM   #1 (permalink)
Ram Year: 2007 Ram QC
Engine: hemi 5.7
Default Tires for towing?
So I am just checking to make sure my tires are good. Currently running toyo open country at2. The size reads as follows P265/70r17. Side wall it's "standard load" stamped on it. Sidewalk also indicates max load of 2535lbs. I have a 6200lbs 2axle trailer. My question is, are these tires safe to tow with? Or should I be looking to get new tires?
Sponsored Ad
Register to remove this ad.
ralaubach is offline   Reply With Quote
Old 08-06-2016, 11:15 AM   #2 (permalink)
cyclepuck's Avatar
Ram Year: 2014 2500 Mega
Engine: 6.4
Default
Those are safe to use. When you tow I'd run the max air pressure that is stamped on tire.
Sent from my SM-G928V using Tapatalk
cyclepuck is offline   Reply With Quote
Old 10-15-2016, 12:10 AM   #3 (permalink)
reindeerman's Avatar
Ram Year: 2011 & 2002
Engine: 4.7
Default
I always upgrade my truck to light truck tires (LT). My truck is for business and most of it's work is towing. If you tow much its worth the change.
6200 lb axle is not necessarily what you are towing, What does your trailer weigh loaded?
reindeerman is offline   Reply With Quote
Old 10-15-2016, 08:38 AM   #4 (permalink)
crash68's Avatar
Ram Year: 2015
Engine: 3.0 EcoDiesel
Default
Even with de-rating the tire for using a P-metric on a truck, the two tires combined weight rating exceed the GAWR.
Unless you tow a lot or go off road with your trailer, the tires should be fine.
crash68 is offline   Reply With Quote
Old 10-15-2016, 10:18 AM   #5 (permalink)
sbarron's Avatar
Ram Year: 2013
Engine: 5.7 HEMI
Default
There is some bad advise here. A "P" or "Passenger" series tire is meant to maintain contact patch with the pavement and provide a more comfortable ride, (meaning the sidewall will flex more than with an LT tire. There are a lot of additional forces applied to your truck when towing. Control can be lost when you have to much side wall flex. If your trailer is light and has a low profile (Shorter than than the CG of truck) your margin is greater, but the safe bet is to tow on "LT" tires. You can get "LT" tires in different load ratings depending on your load. The load rating between a "P" and the "LT" could be the same but the side wall strength and how they react in maneuvering will be different.
RonJon '06 likes this.
sbarron is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Air pressure in tires when towing Jackfate Towing & Hauling 21 03-08-2016 04:17 PM
Which size tires to go with for towing zoomzu Towing & Hauling 16 12-29-2014 01:01 PM
Truck tires and towing audio1der Towing & Hauling 9 03-24-2014 10:48 PM
New Tires and towing pt1655 Towing & Hauling 5 05-18-2013 10:35 PM
Tires for towing? audio1der Towing & Hauling 8 11-28-2012 06:23 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
