Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 2nd Gen : 1994 - 2002 > Towing & Hauling
Towing & Hauling
helper springs
This is a discussion on helper springs within the Towing & Hauling forums, part of the 2nd Gen : 1994 - 2002 category!
I was looking at getting husky springs LP7 helper springs from rockauto so my truck doesn't squat as much when ...
Like Tree2Likes
  • 1 Post By 12vcummins59
  • 1 Post By dudeman2009
Reply
Old 01-10-2017, 12:13 AM   #1 (permalink)
Ram Year: 1996
Engine: Cummins 5.9
Default helper springs
I was looking at getting husky springs LP7 helper springs from rockauto so my truck doesn't squat as much when I haul wood or sometimes hay but it said that the weight rating on the springs is only 1000 pounds which is obviously less than I haul so what is a good option that would help it not squat as much but not be very expensive? It is a 96 ram 2500HD. Thanks.
Sponsored Ad
Register to remove this ad.
12vcummins59 is offline   Reply With Quote
Old 01-10-2017, 05:54 PM   #2 (permalink)
Ram Year: 2001 1500 Sport with enough electrical modifications to make your head spin
Engine: Magnum 360
Default
The springs are rated per side I believe, so unless otherwise stated, double the rating for a set, that is what it will 'add' when loaded directly above the axle.
Air bags are another option, but can be a rip off if you get the cheap ones. Personally, i'd get a set of bags for semis and stick those on there myself, they'll last longer.
Old 01-10-2017, 06:10 PM   #3 (permalink)
BBartow's Avatar
Ram Year: 1995
Engine: 5.9L Magnum
Default
Check out hellwig
__________________
BBartow is offline   Reply With Quote
Old 01-10-2017, 06:54 PM   #4 (permalink)
Ram Year: 2012 ram 2500
Engine: hemi
Default
supersprings are progressive rate ,helwigs , stableloads,timbrens,even a block between your spring pack and the overload will work.all relatively cheap compared to airbags or a stiffer spring pack.personally,i have supersprings for support and airbags for leveling. you don't feel the supersprings when it's not carrying a load.unless you're a total fuckup,you won't kill a set of airbags.and even if you do they'll replace them if you've installed them properly.keeping in mind they are for leveling,not increasing your weight rating.not in a million years will you fit semi bags on your truck,and even if you do it would be as comfortable as falling down the stairs.and you can't double the rate of springs,that's not how they're rated.there's no such thing as "cheap" airbags. sorry,but that whole post is just wrong.
bcbouy is offline   Reply With Quote
Old 01-11-2017, 01:19 AM   #5 (permalink)
Engine: Magnum 360
Default
I'll stand to be corrected on the proper rating on helper spring.
However there is such a thing as cheap airbags. You can get bags and the install kit for sub $200, its nothing more than the bags and a valve stem style connector for pumping them up. Real cheap, super thin walls on the airbags and will blow out the first time you hit a bad set of tracks with them pumped up and under load.
As for Semi bags, Firestone has a kit that will mount single height bags. You can go and get upper frame mounts for bags, and retrofit the lower bag mounts in order to fit single height bags. I never said you'd get standard double heigh bags under there, but Firestone does sell low height bags for the exact use on pickups. I'm not talking the sleeve style, yes those are only for leveling, it could take 75psi to level 1000lbs, but on a small bellows style you'd need less than 40psi.
There are plenty of pickups with heavy duty airbags, its a little more expensive than buying new spring packs plus coils for the front, but it will be far from a horrible ride. Air suspension provides a very smooth ride, and only increases stiffness with load, exactly like helper springs. Semi's only ride hard because of the massive spring packs and high tire pressures they run even at no load.
And yes, bags are not solely used to hold weight, they are used for leveling tractors. However they can take 10klbs load to do so.
We can agree to disagree bcboy.
Old 01-11-2017, 10:02 AM   #6 (permalink)
Ram Year: 1996
Engine: Cummins 5.9
Default
screenshot_2016-08-15-10-01-11.jpg here's what it looks like loaded, I get more in there now because I took the tool box out
Joe w. likes this.
Old 01-11-2017, 01:30 PM   #7 (permalink)
Engine: Magnum 360
Default
A pair of helper springs isn't going to help a ton there. It might raise it by an inch or two, but not enough to level it out.
I stand by my original statement. A set of bellows style airbags will bring that right back. Forget all that garbage about them not being used to hold weight but instead just level. You cant level anything without holding weight. Many air ride travel busses use nothing but bellows style air bags and rubber bottom out protection.
If you really want to get fancy, you can even get a leveling valve and hook it up with an ignition switched compressor so it auto levels. Then when you take the load out it automatically vents pressure from the bags so you don't have to.
Its more work than a set of springs, and a bit more expensive, but a thousand times more satisfactory. Trailering would be a breeze too.
(You still have to pay attention to max vehicle weight ratings though)
12vcummins59 likes this.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Air Bag Kit or Helper Springs? IQRaceworks Towing & Hauling 10 05-07-2017 11:24 AM
14 ram 1500 rear helper springs/air for towing Marksr20 Towing & Hauling 10 05-29-2016 08:45 AM
Hellwig EZ 990 Helper Springs jbrew717 General Discussions 1 05-14-2014 06:25 PM
2" drop shackles w/o helper springs boucy ride justadodgeman Lowered 10 10-23-2013 08:21 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
