Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 2nd Gen : 1994 - 2002 > Towing & Hauling
Towing & Hauling
how hot is too hot?
This is a discussion on how hot is too hot? within the Towing & Hauling forums, part of the 2nd Gen : 1994 - 2002 category!
I have a 96 ram with a v10. I just acquired a 31 foot travel trailer, before that I towed ...
Like Tree5Likes
Reply
Old 07-12-2016, 06:56 PM   #1 (permalink)
Ram Year: 1996
Engine: v10
Default how hot is too hot?
I have a 96 ram with a v10. I just acquired a 31 foot travel trailer, before that I towed a 23 foot ski boat. On a regular day she runs between 185 to 200, but when I tow, she runs 200+ and going up a grade she gets up to about 230. I have talked to several people and I really never get the same answer. Is this too hot, should I be concerned? Btw engine is about 5yrs old and over the years I have replaced the thermostat, radiator, fan clutch, hoses, sensors etc. Also another question on the fan, should it be in a push or pull configuration? Thanks for any help I can get...
Sponsored Ad
Register to remove this ad.
moondogmike is offline   Reply With Quote
Old 07-12-2016, 11:51 PM   #2 (permalink)
dodge dude94's Avatar
Ram Year: 1998 Ram 1500
Engine: 5.9 Magnum
Default
Fans should always be on a pull configuration IMO as in a push config at speed it merely becomes a hindrance. IMO, one should only run a pusher fan in an off road-only vehicle.
For the temps, that is definitely hot for my taste, especially if you have an automatic transmission with the cooler still in the radiator. What kind of speeds and grades are you pulling this boat up? With as much torque as a V10 makes it should be seeing THOSE kind of temperatures.
What I would definitely do is hook a manual temperature gauge inline with the factory sending unit to see what that engine is REALLY running.
__________________
1998 Ram 1500 4x4 QCSB, 360- ebay plenum, Cloyes 3028X, 14in Maggy, DIY CAI, DIY 50mm TB, TransGo shift kit, 285's, LED headlights, Ranch Hand Legend guardOctober 2014 - August 2015 TOTM Winner
dodge dude94 is offline   Reply With Quote
Old 07-13-2016, 11:41 AM   #3 (permalink)
dapepper9's Avatar
Ram Year: 2001
Engine: 5.9L V8
Default
+1. Verify temp. If still bad, double check that you're running the correct coolant as well as not pure antifreeze. Check you oil and make sure you don't have a small headgasket leak or something as well.
__________________
2001 Ram 1500 QCSB, 2" HBS level 285/70/17 Toyo OpenCountry AT2s, M1 2bbl, F&B 52x55mm TB, Pacesetter Longtube headers, 18" Magnaflow, M1 91 Octane canned tune by FlyinRyan, remote start, HS 1.7 RRs, Custom RetroFit 6500K HID
Old 07-13-2016, 08:09 PM   #4 (permalink)
Ram Year: 1996
Engine: v10
Default
To Dodgedude94, the speeds I go is usually 55 and the grades aren't extreme at all. Should I take trans cooler lines out of radiator and bypass it? I think I am going to run a separate temp gauge for coolant and for trans too. thanks. To Dapepper9, oil is clean and I ran the prestone 50/50 premix. Should I try something else? Thanks...
Old 07-13-2016, 08:11 PM   #5 (permalink)
Engine: 5.9 Magnum
Default
Indeed. Being that you live in California, you can safely delete the radiator trans cooler, I would also get a larger aftermarket auxilary cooler for the trans.
Separate gauges are a good start. Figure out what it's running and go from there.
Tryin likes this.
__________________
Old 07-13-2016, 08:19 PM   #6 (permalink)
Ram Year: 2001 1500 Sport with enough electrical modifications to make your head spin
Engine: Magnum 360
Default
210 is as hot as id ever want to see these engines. I had a problem with my thermostat freezing shut this past winter when temps dropped to negative 20. My temps went up to about 240 and I could smell burning before I got to a safe place to shut it down. After 10 minutes I started it back up and floored it, then the thermostat opened right up.
I'd get a cheap thermocouple or non contact thermometer and check the temp right around the coolant temp sensor. With a thermocouple, you are going to want to press it right up to the block, but use a rag or something as your finger being on the probe will skew its reading, on a non-contact try to get the highest reading and go with that, not the average.
dodge dude94 likes this.
Old 07-16-2016, 11:48 AM   #7 (permalink)
Ram Year: 1996
Engine: v10
Default
So I think Im going to run trans cooler lines away from the radiator. whats the best way to do this step by step? Thanks...
Old 07-16-2016, 07:48 PM   #8 (permalink)
Ram Year: 1996
Engine: v10
Default
Okay so I didn't run trans lines. I did notice the temp gauge sensor was broken. So I went got a new sensor and now I can't get it below 200 degrees. Im lost please help..
Old 07-16-2016, 09:20 PM   #9 (permalink)
gofishn's Avatar
Ram Year: 2014 Ram 1500 Express 4X4, Crew Cab, 5'7" Short Box
Engine: hemi 5.7L, 345 cu in
Default
What temp is the thermostat? Whatever the temp, once it hits that temp, it should open and allow fluid, from the radiator, into the engine block, thus cooling it and dropping the temperature. If cooled fluid , from teh radiator, is not dropping your engines temperature, then something is preventing that radiator fluid from cooling, sufficiently.
Blocked channels, improper fan placement, relative to radiator enclosure, etc.
Start from scratch, remove all fluid from radiator and engine.. add fresh, properly mixed fluid. Burp the engine to insure no air pockets in your fluid pathways. run your motor and see wh t the normal operating temps are, with no load.
work your engine by towimng or adding bed weight. check temps.
if still too high, replace thermostat with new, lower temp thermostat. not unheard of, for a new thermostat to be bad, frech out of the box.
__________________
Husky X-ACT Counter Mats, D.Z. Tailgate Assist & Bed Mat, A.R.E. Topper/Cap, Line-X Bed Liner, Mopar Remote Start-Heavy Duty Rubber Mud Flaps-#82213266AB W2W SS Side Steps, Kenwood DDX492, Alpine MRV-F300 Amplifier, Alpine SPR-6x9, Polk Audio DB351, Bilstein [email protected](Front), Bilstein 5100(Rear), TufTruck 1211 Rear Springs, Mevotech UCA's, Engine Bay Paint Mod, Cabin Air Filter mod, Stinger Roadkill Sound Dampener, AVS Vent Visors, Magnaflow 12388 Muffler, H11 to H9 Headlight Mod
gofishn is offline   Reply With Quote
Old 07-17-2016, 11:37 AM   #10 (permalink)
Ram Year: 1996
Engine: v10
Default
Okay gofishn, not to sound stupid, but how do you "burp" the system? Thanks...
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
