Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 2nd Gen : 1994 - 2002 > Towing & Hauling
Towing & Hauling
how hot is too hot?
This is a discussion on how hot is too hot? within the Towing & Hauling forums, part of the 2nd Gen : 1994 - 2002 category!
Okay so heres an update, today I replaced the thermostat replaced the temp gauge sensor and burped the engine. It ...
Like Tree5Likes
Reply
Old 07-17-2016, 09:02 PM   #11 (permalink)
Ram Year: 1996
Engine: v10
Default
Okay so heres an update, today I replaced the thermostat replaced the temp gauge sensor and burped the engine. It seems like everything is working, but I have one question, can a temp sensor be bad right out of the box? Everything seems good tstat is cycling, nothing seems overheated but the gauge is reading 200+.Ive got another new sensor gonna put it in when it cools off...
Sponsored Ad
Register to remove this ad.
moondogmike is offline   Reply With Quote
Old 07-17-2016, 09:34 PM   #12 (permalink)
crazzywolfie's Avatar
Ram Year: 81 93
Engine: 5.2
Default
Originally Posted by moondogmike View Post
So I think Im going to run trans cooler lines away from the radiator. whats the best way to do this step by step? Thanks...
you don't need to bypass the rad trans cooler. i would personally advise leaving it and just adding an additional cooler on the line returning to the pan. the bottom of your rad where the stock trans cooler is located stays fairly cool compared to the upper rad where all the heat is.
it is possibly to have a bad temp sensor out of the box with how cheap things are made but are you sure you are replacing the right temp sensor? i am pretty sure there should be 2 temp sensor on your engine. 1 for the gauge and 1 for the computer. the one for the gauge usually only has 1 wire to the connector
gofishn and Gr8bawana like this.
__________________
81 dodge d150 custom long box 318 670CFM Holley Street Avenger Carb
89 RamCharger 4x4 318/727/3.21 on 33's
93 ramcharger 318 FI 2wd
crazzywolfie is online now   Reply With Quote
Old 07-17-2016, 09:38 PM   #13 (permalink)
Ram Year: 1996
Engine: v10
Default
Yes its the sensor with one prong.
Old 07-17-2016, 09:49 PM   #14 (permalink)
Ram Year: 81 93
Engine: 5.2
Default
well i don't know what your thoughts on it are but you could install an aftermarket temp gauge if you don't trust the sending units or the stock gauge. they are usually fairly cheap and pretty accurate. i like knowing my engines exact temp since i got electric fans
__________________
Old 07-18-2016, 12:23 AM   #15 (permalink)
gofishn's Avatar
Ram Year: 2014 Ram 1500 Express 4X4, Crew Cab, 5'7" Short Box
Engine: hemi 5.7L, 345 cu in
Default
You burp a system by leaving the cap 'off' and allowing the thermostat to cycle through, a few timesd, and then adding more fluid. bascially, jsut isnure you get all teh air out of the system.
what is your thermostat temp setting? before putting a thermostat on a vehicle, place it in pan of water, on your kitchen stove, along with a thermometer, to insure it is set properly adn functioning as designed.
10-15 degree above thermostat setting is not unusual,for engine temps, but should drop down, once system performs and exchange of fluids, form radiator to the engine.
remember, whatever temperature the thermostat is set to open, the fluid must pass from teh engine, to the radiator, then the radiator fluid, which is now cooled, must pass into teh engine, so an engine running slightly higher than the thermostat setting is to be expected. again, the engine should cool down rather quickly though.
if not, my concern would be blocked passage ways within the engine, not allowing a complete fluid exchange or restricting the fluid exchange OR blocked passage ways within the radiator itself.
Placing a thermometer in the raditor, with cap off is another good way to see jsut what teh temp is, of teh fluid coming out of the engine. and seeing what the temp is, of teh fluid right before it goes back into teh engine. either the flauid is not doing a complete fluid exschange or soemthign is preventing it from cooling properly while in the radiator.
__________________
Husky X-ACT Counter Mats, D.Z. Tailgate Assist & Bed Mat, A.R.E. Topper/Cap, Line-X Bed Liner, Mopar Remote Start-Heavy Duty Rubber Mud Flaps-#82213266AB W2W SS Side Steps, Kenwood DDX492, Alpine MRV-F300 Amplifier, Alpine SPR-6x9, Polk Audio DB351, Bilstein [email protected](Front), Bilstein 5100(Rear), TufTruck 1211 Rear Springs, Mevotech UCA's, Engine Bay Paint Mod, Cabin Air Filter mod, Stinger Roadkill Sound Dampener, AVS Vent Visors, Magnaflow 12388 Muffler, H11 to H9 Headlight Mod
gofishn is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
