Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 2nd Gen : 1994 - 2002 > Towing & Hauling
Towing & Hauling
Question about rear springs
This is a discussion on Question about rear springs within the Towing & Hauling forums, part of the 2nd Gen : 1994 - 2002 category!
I have a 96 1500 2 wheel drive that I haul wood with. I have a chassis of a 94 ...
Like Tree1Likes
Reply
Old 09-15-2014, 01:46 AM   #1 (permalink)
Jmrylands's Avatar
Ram Year: 1996
Engine: 318
Default Question about rear springs
I have a 96 1500 2 wheel drive that I haul wood with. I have a chassis of a 94 1500 4x4 sitting out back. I want to know if I can combine the springs of the two trucks. Not to add more carry capacity, but to carry the weight better if that makes sense. The added ground clearance would be helpful also. Trying to do it on the cheap, don't have money for helper springs or air bags. Also trying to make use of the stuff I already have on hand. Another question that I need an answer for, is there any way it lift the front of a 2wd ram, other than bigger tires. It's a sport and being in the woods gets a little hairy sometimes. I know I should have a 4x4, but I have to make do with what I have. Thanks for the responses.
Sponsored Ad
Register to remove this ad.
Jmrylands is offline   Reply With Quote
Old 09-15-2014, 02:00 AM   #2 (permalink)
dodge dude94's Avatar
Ram Year: 1998 Ram 1500
Engine: 5.9 Magnum
Default
So....you're wanting to run two sets of springs on the same axle? Honestly, I can't see how that would be safe with regards to the mounting on the frame. What you could probably do though is take the overloads out of the 94's springs and add them to yours, giving you about 1in of lift and, in theory, more capacity. It would be two sets of overloads, so it would ride like hell, but it would likely accomplish what you want. You could also take the factory block off the 94 and stick it under it as well.
For the front I'd look at a 2 in spacer up there, anything more than that and you're looking at new knuckles, springs and control arms.
__________________
1998 Ram 1500 4x4 QCSB, 360- ebay plenum, Cloyes 3028X, 14in Maggy, DIY CAI, DIY 50mm TB, TransGo shift kit, 285's, LED headlights, Ranch Hand Legend guardOctober 2014 - August 2015 TOTM Winner
dodge dude94 is offline   Reply With Quote
Old 09-15-2014, 02:38 AM   #3 (permalink)
Jmrylands's Avatar
Ram Year: 1996
Engine: 318
Default
I want to know if I can take the two sets apart and combine them into one. To keep it from squatting so bad. I get a load of wood and end up dragging the hitch on the dips in the woods. Last few times I've had dirty and grass in the hitch. I really need a bigger truck but I have to make do with what I have for now. It could ride rough and not bother me that much.
Old 09-15-2014, 02:41 AM   #4 (permalink)
Engine: 5.9 Magnum
Default
Ahhh gotcha. That makes more sense. You should be able to, just remember to install new u-bolts when you put them back in and realize that the spring retainers likely won't want to play nice when putting it back together.
__________________
Old 09-15-2014, 03:00 AM   #5 (permalink)
Jmrylands's Avatar
Ram Year: 1996
Engine: 318
Default
Ok, thanks for the response. I should be able to find different retainers that would work, I would think.
Old 01-13-2016, 07:53 PM   #6 (permalink)
Ram Year: 2001
Engine: Magnum 5.9L
Default
I believe heavier duty rear springs were installed on my truck when it was with the Forest Service making the rear of the truck sit way higher. 2001 4wd 1500 5.9. Think I could take the rear block out and cut the extra length off of my u-bolts? Or are the center pins different sizes?
pwaite92 is offline   Reply With Quote
Old 01-14-2016, 08:08 PM   #7 (permalink)
Gr8bawana's Avatar
Ram Year: 1997
Engine: 5.9
Default
Maybe you could just install a front leveling kit and bring the front end up.
Gr8bawana is offline   Reply With Quote
Old 01-14-2016, 08:17 PM   #8 (permalink)
dapepper9's Avatar
Ram Year: 2001
Engine: 5.9L V8
Default
U bolts are only to be used once.
__________________
2001 Ram 1500 QCSB, 2" HBS level 285/70/17 Toyo OpenCountry AT2s, M1 2bbl, F&B 52x55mm TB, Pacesetter Longtube headers, 18" Magnaflow, M1 91 Octane canned tune by FlyinRyan, remote start, HS 1.7 RRs, Custom RetroFit 6500K HID, Soon to be boosted...
Old 01-15-2016, 01:41 PM   #9 (permalink)
Ram Year: 2001
Engine: Magnum 5.9L
Default
so if I got new u-bolts do you think the spacer would be able to be removed without issue?
Old 01-16-2016, 02:27 PM   #10 (permalink)
Ram Year: truck
Engine: gas
Default
First stop threadjacking threads this is like the third one. Start a new thread, post some pix up for what you are working on and asking about.
New u bolts are a must, removing the rear block will not effect the leaf-spring alignment bolt.
Jimmy68 likes this.
Merc225hp is offline   Reply With Quote
Reply
Bookmarks
Tags
custom springs, leaf springs, load springs
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
rear springs borderram Lowered 0 09-12-2014 10:20 PM
2'' rear springs Kelli25 Lowered 16 07-14-2013 08:12 PM
Rear Springs Question VolsRam Towing & Hauling 8 07-09-2013 11:34 PM
2011 crew cab front/rear springs and rear shocks Trupiano For Sale 1 06-29-2012 10:08 AM
rear springs bigtigga84 Lifted 14 07-08-2011 10:06 AM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
