Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 2nd Gen : 1994 - 2002 > Towing & Hauling
Towing & Hauling
question on towing weight of boat
This is a discussion on question on towing weight of boat within the Towing & Hauling forums, part of the 2nd Gen : 1994 - 2002 category!
Hello I have a 1999 2500 5.9 Diesel I live in Colorado at 9500 ft elevation looking to tow a ...
Reply
Old 01-04-2017, 06:43 PM   #1 (permalink)
Ram Year: 1999
Engine: 5.9
Question question on towing weight of boat
Hello
I have a 1999 2500 5.9 Diesel I live in Colorado at 9500 ft elevation looking to tow a boat and trailer with a combined weight of 15,000 lbs. Im just wondering what type of mods i have to do to the truck,the boat trailer will have trailer brakes I really want to keep it as stock as I can.
Thanks for any info
Sponsored Ad
Register to remove this ad.
gpnhunt is offline   Reply With Quote
Old 01-04-2017, 09:49 PM   #2 (permalink)
Ram Year: 2001 1500 Sport with enough electrical modifications to make your head spin
Engine: Magnum 360
Default
Since you have the diesel, you will be fine on power as long as you haven't put radically larger tires with no change in differential gearing.
At that much weight you should be using a proper hitch, not bumper pulling. If you have trailer brakes, make sure the brake controller is properly setup. Just give your hitch a good once over to make sure everything looks solid and not weakened due to rust.
If you have a manual, pull in 4th gear to minimize wear on the transmission, though some people say pulling in 5th is fine, it will put a bit of extra wear on transmission components.
If you have an automatic, make sure you have an additional transmission cooler installed. If once you get up to cruising speed (I drive 60 normally, but I wouldn't tow anything more than 2Klbs faster than that anyway) if it shifts in and out of overdrive more than once every 5-10 minutes, just turn off the overdrive. Otherwise added wear and premature failure will result.
Make sure the safety chains are free from major rust and are of a consistent thickness, you should adjust the ball receiver so it fits snugly on the ball, but should it come off, you need those chains to hold in order to prevent an accident or death behind you.
All lighting should be tested. All major components should be looked over, including the backside of tires on both the trailer and tow vehicle. Proper inflation on the trailer is critical, too low and the tire may overheat and blow out. Too high and the tire may fail due to heating and overpressure due to said heating. (follow the cold inflation pressure on the sidewall)
Make sure you are alert and aware of your surroundings while towing. In my experience, boats have a habit of rocking and swaying under hard braking, just give yourself some extra space.
Most everything is standard practice, you should be just fine. I only list everything because the one thing you forget, will be the one thing that goes wrong.
Good luck!
Old 01-05-2017, 11:31 AM   #3 (permalink)
Gr8bawana's Avatar
Ram Year: 1997
Engine: 5.9
Default
Everything dudeman said is right on. With your diesel you have enough power to go as fast as you want but as he also said 60 to 65 mph tops safetywise.
Last weekend we were driving on I 10 near Phoenix and a guy in a diesel pulling a toyhauler about 35 feet long passed me doing around at least 80, the speed limit was 75. If something happened in front of him on the packed freeway there is no way he could have stopped fast enough. If he had a blowout he would wipe out a lot of other cars around him.
Gr8bawana is offline   Reply With Quote
Old 01-05-2017, 11:35 PM   #4 (permalink)
dapepper9's Avatar
Ram Year: 2001
Engine: 5.9L V8
Default
As far as mods to help and make it easier/better, load adjusting rear shocks/helper springs/bags will help the ride.
Pulling with an auto, definitely plus 1 to the cooler. In fact, should have that regardless. Also, i would not even allow overdrive to engage until you are up to speed on the highway and turn it back off on hills. Overdrive engages about 15mph too early on these trucks anyways. If your truck is a manual, disregard all that.
Small things to increase tq will also help
__________________
2001 Ram 1500 QCSB, 2" HBS level 285/70/17 Toyo OpenCountry AT2s, M1 2bbl, F&B 52x55mm TB, Pacesetter Longtube headers, CarvenTR, M1 91 Octane canned tune by FlyinRyan, 4.56 gears+Eaton TrueTrack remote start, HS 1.7 RRs, Custom RetroFit 6500K HID
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
2016 towing boat this weekend Ford Towing & Hauling 5 04-22-2016 03:47 PM
heavy boat towing dhay13 Towing & Hauling 19 06-10-2015 11:17 AM
Towing a boat Dez Towing & Hauling 15 01-19-2015 07:34 AM
Towing weight 5.9 purplhrt91 General Discussions 5 01-11-2015 09:20 PM
Towing 25ft boat with 1500 and 3.92 gears cc rider Towing & Hauling 18 03-19-2014 10:04 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
