Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 2nd Gen : 1994 - 2002 > Towing & Hauling
Towing & Hauling
Shifter loose
This is a discussion on Shifter loose within the Towing & Hauling forums, part of the 2nd Gen : 1994 - 2002 category!
Hi I recently got a 2000 Dodge Ram 1500 that is a 5 speed and shifter is loose while it ...
Reply
Old 07-08-2016, 05:52 PM   #1 (permalink)
Ram Year: 2000
Engine: V8 magnum
Default Shifter loose
Hi I recently got a 2000 Dodge Ram 1500 that is a 5 speed and shifter is loose while it is gear. I was wondering if anyone can show exactly where the the bolts are to tighten it. I was also wondering if this is an easy fix that won't cost an arm and a leg to fix at a mechanic.
Sponsored Ad
Register to remove this ad.
Kendall88 is offline   Reply With Quote
Old 07-17-2016, 11:00 AM   #2 (permalink)
mitchbowers's Avatar
Ram Year: 1996 2500 5-speed, soon to be leveled on 33's
Engine: 5.9 Magnum
Default
what probably caused it is leaving your hand on it while it's in gear, putting pressure on it&wears it out. I know it's a hard habit to break for me personally, but will only save the tranny in the long run. as to what would fix it, I have no idea. as long as it's not popping out of gear, it shouldn't be a problem
Sent from my XT1575 using Tapatalk
mitchbowers is offline   Reply With Quote
Old 07-18-2016, 12:09 AM   #3 (permalink)
Ram Year: 2001 1500 Sport with enough electrical modifications to make your head spin
Engine: Magnum 360
Default
The manual lever is directly connected to the ball detent system. If you still have a clear detent in or around each gear the problem is not with that. But if it slides freely from gear to gear, then your detent arm is bent and let the ball fly out, that is a dealer part and requires the valve body to be dropped.
If you still have the dent, the easiest places to look is right under the pedals on the underside of the cab. Just look for the metal rod coming of the driver side of the engine. You will have a cotter pin very soon off the shift lever. From there I believe there is a set screw that is for adjusting where the indicator sits in the dash, that has been known to come loose if it wasn't properly installed.
Old 07-19-2016, 03:18 PM   #4 (permalink)
dapepper9's Avatar
Ram Year: 2001
Engine: 5.9L V8
Default
He's got a 5 speed stick not the auto. There is no manual lever/detent system. His shifter goes directly into the top of his trans.
As to what the fix is I'm not sure. You'd have to pull the carpet back and inspect your linkages. Probably wear as mentioned earlier. There's probably a way to tighten it up but i wouldn't know without looking at one
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Loose gas pedal ChrisJones General Discussion 3 03-02-2016 10:25 AM
Loose ahifter 85 power ram Interior 1 02-19-2016 04:28 PM
Once it's loose, can it ever be tight again? KahneFan Interior 29 10-10-2015 05:32 PM
Loose Rearview :( hemihunter Audio & Electronics 2 06-17-2012 12:08 PM
Loose Steering HemiSport07 Lifted 16 01-25-2012 11:48 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
