Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 2nd Gen : 1994 - 2002 > Towing & Hauling
Towing & Hauling
Towing with 14 R/T help.
This is a discussion on Towing with 14 R/T help. within the Towing & Hauling forums, part of the 2nd Gen : 1994 - 2002 category!
First of I have never towed in my life and my truck does not have a hitch so I will ...
Reply
Old 02-17-2015, 04:17 PM   #1 (permalink)
Ram Year: 2014
Engine: Hemi 5.7
Default Towing with 14 R/T help.
First of I have never towed in my life and my truck does not have a hitch so I will need to buy something adequate. I have to tow a 1989 Iroc Camaro 70 miles from its current location and I have no idea what it weighs. I will be using a Uhaul Trailer to do so. What hitch would you recommend for someone that never tows but may have to move the camaro from time to time. And i see their is a plug in the bumper will I need any wiring to hook up the uhaul trailer will the trailer hook up directly to that plug?
The truck specs are as follows:
2014 Ram R/T
5.7 8 speed, 3.92 LSD rear
Max Towing Capacity - 5,100
Payload - 1381
Belltech 2/4 Lowered (will this matter)
Sponsored Ad
Register to remove this ad.
__________________
2014 Ram R/T, Belltech 2/4 drop, Bakflip VP tonneau cover, Shorty Antenna, Retroshop HID 6k, Deezee tailgate assist, debadged, 5% tint all around, Mufflex DODM80, Rear Hellwig sway bar, Spohn adjustable pan hard bar, S&B CAI, Moes 87mm TB, Diablo T1000 with Hemifever Tune, BT Catch Can, ARH LT 1 3/4" Headers.
aramos3 is offline   Reply With Quote
Old 02-17-2015, 05:00 PM   #2 (permalink)
Graygoose's Avatar
Ram Year: 2015 Silver CC
Engine: 5.7 Hemi
Default
Similar to mine, I did the Draw Tite Max Frame, and do you plan to add helper bags?
Matt at Moes can dial you in for around $100
http://www.moes-performance.com/AIR_...00_p/60818.htm
__________________
2015 Silver CrewCab Bighorn-Retroshop LED tails-Moto Metal-Nitto Terra Grapplers-Kicker Sound System-Bedrug-Extang Trifecta-MGP Caliper covers-Moe's 5" chrome tips
Graygoose is offline   Reply With Quote
Old 02-17-2015, 05:32 PM   #3 (permalink)
Ram Year: 2014
Engine: Hemi 5.7
Default
AIR LIFT 1000 Series Rear Airbags 2009-2014 Dodge Ram 1500 - Stock Height
I had not considered the Durango helper bags, but i may just invent in them to lessen the bottoming out. Mope offers a similar hitch my concern was its towing capacities would that suffice for my application? As for the wiring do you need any extra harness or is it plug and play?
__________________
Old 02-17-2015, 06:10 PM   #4 (permalink)
Graygoose's Avatar
Engine: 5.7 Hemi
Default
Mine was plug and play for my flatbed trailer, ot you can purchase an adapter.
Yes, the helper bags will help for even daily, it's on my list as well, as Ive done the 2/4 drop.
__________________
Old 04-28-2015, 03:44 AM   #5 (permalink)
Ram Year: 2000
Engine: 5.9 Magnum
Default
The trailer from u haul will plug into your trucks trailer socket in the bumper. If the plug doesn't fit you'll have to go to your local auto part store and buy an adapter plug. There's a variety of them but you'll have to find the one that makes the trailer plug into your trucks socket. They're relatively inexpensive. Your truck should have no problem towing the camaro just do your research and buy a quality trailer hitch and make sure you have the correct size ball hitch for the uhaul trailer. If you're unsure what size the trailer needs you can pick up a tri-ball hitch which has the 3 most common ball sizes all on one hitch. Good luck!
__________________
2000 Dodge Ram 1500 Slt Laramie 5.9L Magnum 4X4 Off Road Package, 18" Moto Wheels, 33's, 2.5" Rough Country Leveling Lift, Rough Country 2.0 Shocks, Moog Tie Rods and Track Bar, JVC Single Din stereo w/ Kicker Component Speakers
Awojey is offline   Reply With Quote
Old 04-28-2015, 06:41 AM   #6 (permalink)
Dubstep Shep's Avatar
Ram Year: 2014 R/T
Engine: 5.7L Hemi
Default
The reason the towing rating is so low on the R/T trucks compared to the other rams is the wheels, tires, and suspension.
You've replaced the suspension, and if you add helper bags you should be fine there.
You run a little bit of a risk towing with the factory 22" wheels and tires. Supposedly they aren't rated for as much load as the 20" wheels are, which makes sense when you look at the sidewall.
__________________
MOD LIST UNDER CONSTRUCTION
BUILD THREAD:http://www.ramforum.com/f17/dubstep_...t_build-55252/
Dubstep Shep is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
towing bugaboo1 Towing & Hauling 16 02-18-2015 11:55 AM
Why is the R/T towing so low? Dubstep Shep Towing & Hauling 32 09-06-2014 08:04 PM
Towing on 87 smurfs_of_war Towing & Hauling 18 01-08-2014 10:28 AM
Towing ewbloom Towing & Hauling 7 09-03-2013 11:00 AM
Ram 5.2 Towing..? ktm1217 Towing & Hauling 13 09-05-2011 07:02 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
