Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 2nd Gen : 1994 - 2002 > Towing & Hauling
Towing & Hauling
A trailer with no brakes?
This is a discussion on A trailer with no brakes? within the Towing & Hauling forums, part of the 2nd Gen : 1994 - 2002 category!
I'm going to be using my '95 Dodge Cummins 3500 dually to haul a 1967 ford f100 on a Uhaul ...
Like Tree2Likes
  • 2 Post By tsc
Reply
Old 12-21-2015, 12:57 PM   #1 (permalink)
Ram Year: 1995
Engine: Cummins diesel
Default A trailer with no brakes?
I'm going to be using my '95 Dodge Cummins 3500 dually to haul a 1967 ford f100 on a Uhaul car transport trailer. I've reserved the trailer and also found out that the trailers Uhaul rent don't have electric brakes. Is that safe? The Ford being towed weighs about 3500 pounds. It'll be a cinch for my truck to haul, but I'm concerned about downhills and stopping power on the trailer. Has anyone towed a load like this on a Uhaul trailer with any problems?
Sponsored Ad
Register to remove this ad.
Mpeach1976 is offline   Reply With Quote
Old 12-21-2015, 12:58 PM   #2 (permalink)
dodge dude94's Avatar
Ram Year: 1998 Ram 1500
Engine: 5.9 Magnum
Default
You have a 1 ton....it'll be just fine. You may feel it push a little bit, but you'll still stop fine.
__________________
1998 Ram 1500 4x4 QCSB, 360- ebay plenum, Cloyes 3028X, 14in Maggy, DIY CAI, DIY 50mm TB, TransGo shift kit, 285's, LED headlights, Ranch Hand Legend guardOctober 2014 - August 2015 TOTM Winner
dodge dude94 is offline   Reply With Quote
Old 12-21-2015, 01:35 PM   #3 (permalink)
Ram Year: 2011
Engine: Hemi 5.7
Default
You'll be fine since your ram is big enough.I used to be a tow truck driver. My wrecker was a 92 f350 7.3 diesel 4x2. I've pulled several vehicle the same size and larger without any type of braking system without any problems. Just give yourself some extra distance and time and you should be fine.
Rlaf75 is offline   Reply With Quote
Old 12-21-2015, 02:21 PM   #4 (permalink)
tsc
Ram Year: 2015
Engine: Hemi 5.7
Default
Some Uhauls have hydraulic brakes installed.
I'm pretty certain if you're going to be using one of their car haulers. It will have hydraulic brakes, since I can't see them renting out something that wasn't "legal". Most states and province's require trailer brakes over a certain weight (anywhere from 2K to 3500K+).
Uhaul tends to use hydraulic brakes oppose to electric, since it covers their backside. If they came with electric, they would have to ensure that the renter had an electric brake controller in the vehicle. This way, with the hydraulic, it's attached to the trailer and it's one less thing they have to worry about.
Merc225hp and dodge dude94 like this.
tsc is offline   Reply With Quote
Old 12-21-2015, 06:51 PM   #5 (permalink)
Ram Year: 2011
Engine: Hemi 5.7
Default
I've towed a 1950 Studebaker pickup (probably around 3500#) on a U-Haul car hauler twice - once with a U-Haul truck from TX to NC and then from Raleigh to Louisburg (40 miles) with my Ram (1500) - they do have hydro brakes, but both times I didn't feel there wasn't enough braking available.
OutLore is offline   Reply With Quote
Old 12-21-2015, 07:56 PM   #6 (permalink)
RonJon '06's Avatar
Ram Year: 2006, 1985
Engine: 5.7, 360
Default
I've towed a few 1/2 ton pick ups with my '06 2500 on a trailer that has electric brakes...that don't work...and its been fine. Leave yourself some extra room like Rlaf75 suggests and if the Uhaul has hydraulic brakes even better.
__________________
2006 | 1500 | MCSB | 4x4 | Built 5.7L Hemi
Forged Internals, Edge 2600, HD Trans cooler, JBA Shorties
1985 | W350 | RCLB | 360 | Dana 44/60, Firestone Ride-Rite Airbags
RonJon '06 is offline   Reply With Quote
Old 12-21-2015, 08:07 PM   #7 (permalink)
Ram Year: 2015
Engine: Hemi 5.7
Default
Knowing how U-HAUL operates,they've probably never serviced the brakes.
CVX20 is offline   Reply With Quote
Old 12-21-2015, 08:50 PM   #8 (permalink)
Ram Year: 2012 ram 2500
Engine: hemi
Default
if i were you i wouldn't tow a truck on a trailer without some kind of braking system.if for any reason the trailer comes away from the truck its going to kill someone.don't think it can't happen to you.
bcbouy is offline   Reply With Quote
Old 12-22-2015, 09:43 PM   #9 (permalink)
Ram Year: 2001 ram 3500
Engine: V10
Default
At least make sure you have enough tongue weight.I was towing my race car on a trailer with no brakes. I thought I had positioned the car on the hauler with enough tongue weight, I was wrong. It was about 3 or 4 inches shallow. I had just gotten on the freeway, there was a long incline, then when I reached the crest of the hill and started down the other side, I touched the brakes and the trailer started wagging. I could see the trailer on my left side with my peripheral vision, when I was facing forward! Fortunately, the rush hour traffic parted, and slowed waiting for me to crash, but I was able to wrestle it to a stop. Had I had trailer brakes, It probably wouldn't have happened, or I could have settled it with the brake controller.
Rustycowl69 is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
brakes ----upgrade to better brakes trx680 General Discussions 0 10-10-2015 11:12 AM
traction control light on, service trailer brakes, and No CC reb0957 Heavy Duty 6 09-10-2015 02:53 PM
Trailer brakes disconnected without a trailer hooked up Southpaw959 Towing & Hauling 0 05-18-2015 12:01 AM
towing w/o trailer brakes vonshep Towing & Hauling 32 01-14-2015 02:08 PM
help locking up trailer brakes with controller at 0 Richard R Towing & Hauling 6 08-16-2014 01:12 AM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
