Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > Dodge Ram Cummins Diesel Forum > Engine and Performance
Opinions on Cummins Engine Break-in
This is a discussion on Opinions on Cummins Engine Break-in within the Engine and Performance forums, part of the Dodge Ram Cummins Diesel Forum category!
I'm new to this forum, but have owned Dodge RAM trucks since 1996. While I've searched forums with keywords on ...
Sponsored By: Moe's Performance
Reply
Old 08-30-2011, 04:55 PM   #1 (permalink)
Ram Year: 2011
Engine: Cummins 6.7L
Default Opinions on Cummins Engine Break-in
I'm new to this forum, but have owned Dodge RAM trucks since 1996. While I've searched forums with keywords on break-in and such, I haven't found anything. My apologies in advance if this is an old topic that I've missed.
I'm picking up my new 2011 RAM 3500 tomorrow about 500 miles away. As this is a brand spankin' new (8 miles on the odom), I'm concerned about driving it at constant highway speeds for 6 - 7 hours.
Over the years, I've heard various opinions about what to do and not to do. I've also heard that "today's engines" are machined to much finer tolerances that in years gone by, and engine break-in is no longer the issue it once was. So, I've heard that you shouldn't tow because of the added stress on the entire powertrain. I've also heard you shouldn't drive at constant speeds for long periods of time and you shouldn't rev the engine up.
Does anyone have any scientific or empirical data (pipe in your gut feelings as well) or details on what engine break-in is recommended these days for maximum engine life and fuel economy?
Thanks in advance.
Sponsored Ad
Register to remove this ad.
tadalex is offline   Reply With Quote
Old 08-30-2011, 05:12 PM   #2 (permalink)
Bluesmoke91's Avatar
2nd GEN Site Mod
Ram Year: 2007
Engine: Hemi 5.7
Default
Cummins are work horse engines....id be surprised to see that they would need any sort of break in period
__________________
07 Ram 1500 Hemi 4x4 Big Horn
Few Mods. Click my build thread.
http://www.ramforum.com/f17/bluesmok..._thread-27206/.
Bluesmoke91 is offline   Reply With Quote
Old 08-30-2011, 06:05 PM   #3 (permalink)
ramhunter9's Avatar
Ram Year: 2012
Engine: P-Star Jeep Wrangler
Default
They don't get broke in until about 100k. So you are fine. Drive like normal bud it's a cummins it's built for anything.
I will also move this to the cummins section for you so you can get better feedback
ramhunter9 is offline   Reply With Quote
Old 08-30-2011, 06:36 PM   #4 (permalink)
dripley's Avatar
Ram Year: 2002 2500 ho 6 speed 4X4
Engine: 5.9 24v cummins
Default
i bought mine in late 01 when my v10 blew. i was concerned with the same thing. the mech's at the dealer told me to drive the piss out of it. the owners manual said the same thing although worde differantly. the manual says "Your Cummins 24 valve Turbo Diesel does not require a normal break-in period due to its construction" it further states 'Because of the construction of the Cummins Diesel engine, engine run in is enhanced by loaded operating conditions which allow the engine parts to achieve final finish and fit during the first 6k miles" i took delivery of mine and strapped an 11k 5th wheel to the back of it and drove it from SC to NJ at highway speed. since i only move my rv 3 or 4 times a year mine did not break in in 6k miles, it was more like 25k miles. it was like getting a new truck when it finally started to wear in. if just got stronger and stronger for about 5k miles. today the engine is stonger than when i was new.
it probably would not hurt to ask the dealer and read the manual to be sure nothing has changed with the cummins. if it has not load it up and drive it. they were not made just to ride around in, they were made to work and work hard.
dripley is offline   Reply With Quote
Old 08-30-2011, 07:14 PM   #5 (permalink)
ramhunter9's Avatar
Ram Year: 2012
Default
This ^^^
Old 08-30-2011, 10:30 PM   #6 (permalink)
Mopar1973Man's Avatar
Ram Year: 1996, 2002
Engine: 1996 Dodge 1500 (V8-5.9L) & 2002 Dodge Ram 2500 (5.9L Cummins)
Default
Originally Posted by ramhunter9 View Post
This ^^^
Agreed... Hitch up a trailer and work the truck...
The only thing I would do is allow the engine to fully warm up before laying your foot into it. So fire it up and put it gear drive nice and easy till the engine temp is up fully then you can cut her loose... (Grin)
With any truck I would suggest you consider getting gauges for it eventually. Best way to protect your investment!
As for 6.7L truck with the DPF they are not daily drivers trucks. You need to get the EGT's up to 1,000*F for a period of time every day to burn the carbon from the DPF filter and to keep it from Regen'ing all the time. Once again these truck are made to work...
Heck I got a buddy with a 01 Dodge Cummins that rolled the 1 MILLION miles... These trucks are designed for the long haul...
__________________
2002 Dodge Ram 2500 (Cummins Diesel) -=- 1996 Dodge Ram 1500 (5.9L Magnum)
Mopar1973Man is offline   Reply With Quote
Old 08-30-2011, 10:43 PM   #7 (permalink)
05singlecabHEMI's Avatar
Ram Year: 2005
Engine: 5.7 HEMI
Send a message via Yahoo to 05singlecabHEMI
Default
^^bad ass!
__________________
55W Bixenon Digital HIDs, Retro shop projectors with halos, LED Switchback turns, Pacesetter LT headers dual exhaust flow master 40series dumped before the axle, raceland 3" cutoutvararam air intake, 1.5inch leveling kit, Dakota AT^2 tires, plastidipped wheels, DSP 93octane tune, rocket wire, aeroforce gauge in a SRT 10 pillar with A/F ratio, color matched gill, plasti dipped bumpers. Sonnex Line Booster, Bedrug, Extang bed cover, ground force drop shackles. 85MM throttle body.
05singlecabHEMI is offline   Reply With Quote
Old 08-31-2011, 10:31 AM   #8 (permalink)
MarbleCrusher's Avatar
Ram Year: 2002
Engine: VP Cummins
Default
Always makes me feel good when i see that picture!
-Jordan-
__________________
-02 Dodge 2500 cummins 4x4 6spd. Quad XZT+, Volant CAI, road armor w/ lonestar guard line-x'd, Fass 95 , 3in lvl kit, bilsteins.
-68 F-100, grandad bought it new gave it to me when i was 16 been restoring bak to factory ever since.
MarbleCrusher is offline   Reply With Quote
Old 08-31-2011, 10:31 AM   #9 (permalink)
Default
Originally Posted by 05singlecabHEMI View Post
^^bad ass!
More coming up to bat...
Dodge Cummins Milestones
So truely the Cummins engine don't complete break in period for at least 100K miles... Midlife is right around 400-500K miles if taken care of. The million mile engine I is still running back and forth across the US hauling boats daily. As for the million mile truck he blew a head gasket at around 700K miles (coolant jack to exterior) and when the head was off he still had cross harching in the bores... It not even hurt!
__________________
Old 08-31-2011, 10:36 AM   #10 (permalink)
quietpeen's Avatar
Administrator
Ram Year: 2016 1500 Sport Crew Cab 4x4
Engine: Hemi 5.7
Default
welcome to RF. I've always heard to to put them to work
__________________
RamForum.com Administrator
Charger Owners sign up on www.chargerforum.net
quietpeen is offline   Reply With Quote
Reply
Tags
break-in, new engine
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Performance break down on my new hemi ram? JASONRAM1500 Engine & Performance 9 08-08-2011 05:15 PM
Break squeaking Captain McGillycutty General Discussions 8 06-24-2011 11:58 PM
Cant catch a break badfish888 General Discussions 16 11-20-2010 09:45 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
