Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > Dodge Ram Cummins Diesel Forum > Engine and Performance
Poor Fuel milage
This is a discussion on Poor Fuel milage within the Engine and Performance forums, part of the Dodge Ram Cummins Diesel Forum category!
I have a 2012 Ram 3500 Diesel with the Cummins engine, I have 13,500 miles on it and I can't ...
Like Tree4Likes
Sponsored By: Moe's Performance
Reply
Old 01-18-2015, 02:10 PM   #1 (permalink)
Ram Year: 2012
Engine: cummins diesel
Question Poor Fuel milage
I have a 2012 Ram 3500 Diesel with the Cummins engine, I have 13,500 miles on it and I can't get over 12 miles per gallon. I am not pulling any loads. The dealer checked the computer and nothing is wrong with it. Has anyone else had this problem, did I just get a lemon and Is there anything I can do or should I just trade it for a Ford.
Sponsored Ad
Register to remove this ad.
olie is offline   Reply With Quote
Old 01-18-2015, 03:21 PM   #2 (permalink)
Cummins Powered's Avatar
Ram Year: 2008 Ram 2500 4x4 3.73 gears,1994 Ram 2500 4x4 12 valve modified, Industrial Injection #5 fuel plate
Engine: 6.7 Cummins, 5.9 Cummins
Default
With these newer 6.7's with the emissions you will not see the best of miles per gallon. There are claims of guys getting 20 miles to the gallon with these trucks, but these claims are not true. You want better mileage, and air-flow delete the emissions, and get a tuner so the truck will not go into limp mode.Other wise you will just have to live with fact that emissions are part of your truck, and you'll have to deal with that aspect. There are a few tips to achieve a little better miles per gallon. Check your air filter, fuel filter, proper tire pressure, a high lift kit with bigger tires also affects mileage. There is a product called Power Service Diesel Kleen, it lubricates the entire fuel system, cleans dirty injectors, less down shifting, higjer cetane boost, protects pumps, faster cold starts, and also prevents injector sticking. Use it at every fill, I mean every fill up to get the benefits. Hand calculation is way more accurate set up versus reading off of your truck readings.
__________________
H&S Mini Max 225 tune,fire ring,Carrillo Rods,Helix 2 Cam,Hamilton valve springs,125HP nozzles,grid heater delete,ARP 625 with Vulcan gaskets,Air Dog II 200,Banks Ram Air,Banks Techni Cooler,Banks Super Scoop,Banks double shot water meth injection,BD intake manifold, DPP Spectre VGT turbo Howitzer 66 comp 67/70 with race gate, modified fuel rail, stroker CP3, Steed Speed competition manifold,Silverline 5 inch turbo back,NADP Heavy Hauler Race series transmission,Kore VR coils,Fox shocks.
Cummins Powered is offline   Reply With Quote
Old 01-18-2015, 03:24 PM   #3 (permalink)
NYCruiser's Avatar
Ram Year: 2014
Engine: Hemi 5.7
Default
A similarly equipped Ford isn't going to be much better.
NYCruiser is offline   Reply With Quote
Old 01-18-2015, 03:46 PM   #4 (permalink)
Default
It's any of the BIg 3, it's very sad and disappointing what they are doing to these trucks. Cummins, Duramax, and the Powerstroke are improving the engine design, beefing up the transmission, bigger turbos, as seen in the new 2015 6.7 Powerstroke. Could you imagine if these 3 diesel trucks with no emissions, all you would need is basic tuner, and turbo-back. To the above post, forgot to mention with only 13,500 miles your engine is not broken in yet, it will improve mileage but nothing dramatic.
__________________
Old 01-19-2015, 02:25 AM   #5 (permalink)
smiley3303's Avatar
Super Moderator
Ram Year: 2009 Ram 1500 Laramie Crew 4WD
Engine: Hemi 5.7L
Default
The nearsightedness of these emissions sure sucks. You now have to burn more fuel to save the environment? Yup makes no sense because more fuel means more emissions somewhere else to get it to your tank. Plus urea which also has to be processed and delivered for the newest ones causing more emissions and problems. It reminds me of the electric car issue where people try and argue they are clean and better for environment. They still cause emissions they just don't do it at their own tailpipe it is done at a coal or nuclear plant. Emissions controls make sense but not ones that are illogical.
__________________
smiley3303 is offline   Reply With Quote
Old 01-19-2015, 08:12 AM   #6 (permalink)
Sparkyy's Avatar
Ram Year: 2007
Engine: Hemi 5.7
Default
I use the same reasoning with people about electric cars. Also there is the fact that the electric car has a battery that has to be replaced every so often. Which is more damaging than the Hemi will ever be in its lifetime.
To OP, not sure about diesels but gas trucks get worse mileage in the winter months than summer, so that could play a role too. But as everyone has said, it's all this friendly new emissions crap on it.
Cummins Powered likes this.
Sparkyy is offline   Reply With Quote
Old 01-20-2015, 09:26 PM   #7 (permalink)
Default
I really feel for the first time buyer, they have no idea what they are getting themselves involved when it comes to these emissions on these diesel trucks. The first time buyer sees the RAM commercial, with a Cummins pulling a horse trailer, they get very excited and go to a dealership. The salesman, and the finance manager not telling them anything when it comes to issues involving these trucks. We are not just talking about a kitty cat(converter). Very strict expensive emissions parts. They take the truck home, well within a few months they don't understand why they are getting 10 miles or so to the gallon, check engine light comes on, well upon taking a trip to the dealership the service guy tells them soot is clogged the egr valve and turbo, and in some cases the DPF too. That's when they start to acknowledge and learn about the emissions on these newer diesel trucks. Several things happen, they either deal with and exept what's in front of them, they trade there truck in for a prius, or an import rice burner fart can.
__________________
Old 02-25-2015, 01:51 AM   #8 (permalink)
Arctic-Rodz's Avatar
Ram Year: 2014 2500
Engine: 6.7L Cummins
Default
To the OP
is your truck at stock height? Original tire and wheel?
I recently got my CTD Ram 2500 and love it. MPG is very similar to what my 1500 6 speed hemi was.
Also, is the mpg you're seeing all city?
I'm seeing 13 mpg in the city with stop and go traffic. 14mpg mixed highway with some light towing and 18mpg on the highway averaging 75mph.
All hand calculated.
My truck reads 2mpg average more. When I first got it, and drive it home it showed 20mpg on the highway trip but the hand calculated showed 18. Not bad really, would love to see 20 though
__________________
-2014 Ram 2500 Crew Cab Tradesman Cummins 4x4
-2013 Triumph Tbird Storm : With MODS
-2014 VW GLI Autobahn
-1997 Camaro Z28 30th Anniversary Edition : With MODS
Arctic-Rodz is offline   Reply With Quote
Old 03-21-2015, 12:38 PM   #9 (permalink)
Ram Year: 2011
Engine: HEMI 5.7
Default
Low teens mileage is why HD trucks aren't required to get EPA certified for mileage testing. It would turn a lot of people away from buying a HD, be it gas or diesel, for personal use. Axle ratios are often lower than half ton trucks, and HD's also weigh more, even with the gas engine. An HD that gets double digit mileage is good in my book.
__________________
2011 RAM HEMI Quad Cab SXT 4x4 in Silver.
67,000kms
htwo is offline   Reply With Quote
Old 05-31-2015, 04:49 PM   #10 (permalink)
Ram Year: 2014
Engine: 6.7 cummins
Default
I just purchased a 2014 with a 6.7. I was leery of it with all the emissions(dpf,def,and such).I've been in the trucking industy for over 20 years and ive seen the negative effect these new emissions have on 2007 and newer class 8 trucks.Long story short,took the family from california to kentucky and back to california.The average mpg for over 5300 miles was 20.9. In some cases just running the interstate at 70 to 80 mph i was getting 23 to 23.5. This is off of the truck trip meter and doing the math at everyfill up.For those that claim its impossible you probly wont believe it,i guess i could post pictures of my trip meters.For anyone else looking to buy these newer 6.7 my advise is to spec your truck accordingly.
westcoastflatbedder is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
2012 4.7 VERY POOR Fuel mileage?!! Duckcommanderdodge Tech Info 0 01-05-2015 09:00 PM
Poor fuel economy/loss of power Jmdoft91 Engine & Performance 23 07-27-2014 10:15 PM
Terrible fuel milage ramtruck4life General Discussions 6 10-27-2013 11:02 AM
Poor Fuel mileage bbd90 Engine & Performance 1 07-16-2013 10:58 AM
Improving Fuel Milage EMK Engine & Performance 26 03-22-2013 12:21 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
