Timing Question
Truemagnum15
Washington State
5.9L
Hi,
We have a 1999 Dodge Ram 1500 with a 5.9 V8 engine.
Since one cannot perform the "finger over the plug hole" technique because of the presence of a heat shield, my question is as follows:
If #1 cylinder is at the top, the timing marks on the harmonic balancer line up and the rotor points pretty close to #1, can we assume we are at top dead center on the compression stroke?
Thank you in advance.
radikio
