Header bolts
ralaubach
CA
2007 Ram QC
Hey Matt, I was looking on the site but could not find the grade 8 bolts you guys recommend for doing the headers. Need to replace the gaskets and have those waiting in my shopping cart, but need the bolts. I am not wrong in assuming bolts are a one time use kind of thing correct?
Thanks for the help.
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
Unfortunately, we do not carry the Stage 8 bolts anymore. They just were not able to give us decent pricing to be competitive. Another cheaper option is to just use the factory 6.1 exhaust manifold bolts. These should be in stock at your local dealership, and are about half the cost of the Stage 8.
nolimits76
Matt is giving you good info -- listen to him.
Most prefer to use the following bolts, that have factory lock-tite applied to keep them from coming loose on you. Price isn't horrible either. Steve White is a dealership with a large online presence in many forums. Contact Luke and he will hook you up. Yes, he charges shipping but my local dealer usually won't meet his prices.
Good luck!
06503131 - (16 EA) - Header Bolts; M8x1.25x30; Factory Lock-Tite applied
TylerB
FL
All great info! That's why Matt is the best, he still helps the customer even if he isn't gonna be making a sale.
R
ralaubach
CA
2007 Ram QC
Thanks matt once again I appreciate your help. Don't know if i told you, but discovered a bolt had broke off when i was installing the ARH long tubes i got from you. Hence my need for gaskets and bolts... Sadly I had no time to fix it at the moment due to leaving for deployment soon after. Just now getting around to it....
