1998 - 2002 Dodge Ram 2500 Truck Power Heated Towing Mirror with Support Bracket Pair
1ATony
hemi
CHECK US OUT HERE FOR GREAT PRICES 1998 - 2002 Dodge Ram 2500 Truck Power Heated Towing Mirror with Support Bracket Pair
FREE SHIPPING IN THE LOWER 48 STATES!!!
This mirror PAIR with support brackets is a direct replacement of the original fold out style tow mirror. The Mirror rotates 90 degrees from a horizontal orientation, to a vertical orientation that gives you a better angle of sight for towing a trailer.
You can also upgrade a standard style power heated mirror with this mirror PAIR if you desire more vision when towing. Some applications may require the re-use of your mounting studs. These mirrors come with long mounting studs like the original application.
Mirror specifications:
Comes as a PAIR
Fits both the LH (Driver) & RH (Passenger) Sides
Power
Heated
Folding - Can lay flat against the door
10X7 glass size
Replaces dealer part number: 55076488AE, K55156129AC, 55156129AC, 55076489AE, K55156128AC, 55156128AC
Measures approximately 18" long folded in and 24" long folded out from base
Direct replacement
Injection molded textured black plastic housing
Built to strict quality control standards
INCLUDES mounting brackets*
Please CLICK HERE to see wiring routing instruction sheet so as not to pinch mirror wiring harness.
*PLEASE NOTE: If your vehicle did not come with this mirror pair originally and it is being purchased as an upgrade, the included reinforcement mounting brackets will have to be used to allow the mirror pair to work properly.
Installation Note:
Use caution when installing mirror not to pinch wires near mounting area. Pinched wires can result in shorting.
These mirrors are a direct bolt on replacement to your original mirrors.
1 Year Warranty
This item is backed by a 1 Year Manufacturers Warranty. In the event this item should fail during intended use, we will replace the part free of charge (excludes shipping charges) for the original purchaser. Please keep your invoice for proof of this warranty.
More information on tow mirrors can be found here: Tow Mirror Information
1ATony
1ATony
hemi
ttt
1ATony
1ATony
hemi
ttt
1ATony
1ATony
hemi
ttt
1ATony
1ATony
hemi
in stock ready to ship
1ATony
1ATony
hemi
In stock ready to ship
1ATony
1ATony
hemi
1ATony
1ATony
hemi
1ATony
1ATony
hemi
Back in stock
1ATony
1ATony
hemi
1ATony
1ATony
hemi
ttt
1ATony
1ATony
hemi
Back in stock
1ATony
1ATony
hemi
Back in stock
1ATony
1ATony
hemi
ttt
1ATony
1ATony
hemi
If anyone needs help or has questions about tow mirrors for your vehicle, reply to this post or PM me and I can help you guys out.
Tony
1ATony
1ATony
hemi
1ATony
1ATony
hemi
Back in stock
1ATony
1ATony
hemi
1ATony
1ATony
hemi
Gear up for RV and boating season!
1ATony
1ATony
hemi
Get ready to haul your RV!
