- Apr 19, 2011
- 3,245
- 149
- 2006
- hemi
VISIT US HERE FOR GREAT PRICES 2000-2001 Dodge Ram 1500 Truck 4WD Front Wheel Bearing & Hub Assembly for Models with Rear Wheel ABS Pair
FREE SHIPPING IN THE LOWER 48 STATES!!!
This replacement wheel bearing & hub assembly is just what you need to get your vehicle in good working order again.
Specifications:
Comes as a PAIR
Fits both LH (Driver Side) & RH (Passenger Side) FRONT
3 Bolt Flanges
Fit 5 Lug Wheels
Replaces dealer part number: 52009863AA
Direct replacements
Built to strict quality control standards
New wheel studs installed
Fit 4WD (Four Wheel Drive) Models only
Fit models with RWAL (Rear Wheel Anti-Lock Brakes) only
Do NOT fit models with 4 Wheel ABS (Anti-Lock Brakes)
This wheel bearing & hub assembly is a great replacement and has good cost savings over a unit from the dealer.
Quality
You will not have a problem with our product. If you are comparing us to someone selling a brand name product remember brand names are only as good as the company selling them. Both Bizrate.com and The Better Business Bureau recognize 1A Auto as a trusted online seller. You will be pleased with what you find out about us.
You don't want to be delayed by a defective part. 1A Auto wheel hub & bearings are all tested prior to shipping.
Fit Guaranteed
This hub & bearing will install just as your original does. You can use your existing hardware.
Save time and money with this direct fit hub bearing assembly. No trips to the auto parts store or extra time trying to match up and press bearings.
Hub installation is a degree more difficult than changing a tire on most vehicles.
Value
Some shops and dealers charge more for parts and repairs when they think the customer doesn't know what is involved. Now you can get the value you deserve. Knowing what this repair entails can be the difference between the value of doing it yourself, or the pain of a costly part or repair bill.
2 Year Warranty
This item is backed by a 2 Year Manufacturers Warranty. In the event this item should fail during intended use, we will replace the part free of charge (excludes shipping charges) for the original purchaser. Please keep your invoice for proof of this warranty.
This part replaces:
Reference #: 515038 x2
Specifications:
Comes as a PAIR
3 Bolt Flanges
Fit 5 Lug Wheels
Direct replacements
Quality
Fit Guaranteed
Value
2 Year Warranty
This part replaces:
