- Apr 19, 2011
- 3,245
- 149
- 2006
- hemi
SHOP HERE 2009-2010 Dodge Ram 1500 Truck Front Performance Cross Drilled & Slotted Zinc Coated Brake Pad & Rotor Kit Premium Posi Semi-Metallic
FREE SHIPPING ON ALL ORDERS
This performance brake rotor & posi pad set is just what you need to get your vehicle stopping in good order again!
Brake Pad Specifications:
- Premium Posi Semi Metallic brake pads
- 4 Piece Front brake pad set
- Includes shims
- Direct replacement
Brake Rotor Specifications:
- Comes as a matched pair
- Includes both LH (Driver) & RH (Passenger) Side FRONT
- Cross drilled, Slotted, And Zinc Coated
- Replaces dealer part numbers: 52010080AA, 52010080AB, 52010080AC, 52010080AE
- Fits 5 Stud Wheel
- 13.2" (336mm) Diameter
Premium Positive Molded Brake Pads Features and Benefits:
The very same manufacturing process the original equipment manufacturers use
High density friction material for long pad life
Less resin content virtually eliminates brake fade and glazing
Reduced dusting for both Ceramic and Semi-metallic materials
Quality multi-layered shims and pad chamfering provide smooth and quite braking
ALSO FITS THESE VEHICLES
VEHICLE FIT
- 2007-2009 Chrysler Aspen Front Performance Cross Drilled & Slotted Zinc Coated Brake Pad & Rotor Kit Premium Posi Semi-Metallic
- 2009 Chrysler Aspen Hybrid Front Performance Cross Drilled & Slotted Zinc Coated Brake Pad & Rotor Kit Premium Posi Semi-Metallic
- 2007-2009 Dodge Durango Front Performance Cross Drilled & Slotted Zinc Coated Brake Pad & Rotor Kit Premium Posi Semi-Metallic
- 2006 Dodge Ram 1500 Truck Front Performance Cross Drilled & Slotted Zinc Coated Brake Pad & Rotor Kit Premium Posi Semi-Metallic (excluding SRT-10 & Mega Cab)
- 2007-2008 Dodge Ram 1500 Truck Front Performance Cross Drilled & Slotted Zinc Coated Brake Pad & Rotor Kit Premium Posi Semi-Metallic (excluding Mega Cab)
- 2009-2010 Dodge Ram 1500 Truck Front Performance Cross Drilled & Slotted Zinc Coated Brake Pad & Rotor Kit Premium Posi Semi-Metallic
- 2011-2013 Ram 1500 Truck Front Performance Cross Drilled & Slotted Zinc Coated Brake Pad & Rotor Kit Premium Posi Semi-Metallic
