2011-2013 Ram 1500 Truck Rear Performance Cross Drilled & Slotted Zinc Coated Brake P
1ATony
hemi
SHOP HERE FOR GREAT PRICES 2011-2013 Ram 1500 Truck Rear Performance Cross Drilled & Slotted Zinc Coated Brake Pad & Rotor Kit Premium Posi Semi-Metallic
  • DIRECT REPLACEMENT
  • FREE SHIPPING
  • SUPERIOR QUALITY
cbo
Why are these only for 2011-2013 trucks?
1ATony
1ATony
hemi
Here's a fit list of all of the applications that these brake rotors and pads fit. If you do not see your vehicle on the list, reply back with your application, and I can see if we have a set for your vehicle.
VEHICLE FIT
  • 2004 Dodge Durango Rear Performance Cross Drilled & Slotted Zinc Coated Brake Pad & Rotor Kit Premium Posi Semi-Metallic
  • 2002-2003 Dodge Ram 1500 Truck Rear Performance Cross Drilled & Slotted Zinc Coated Brake Pad & Rotor Kit Premium Posi Semi-Metallic
  • 2004-2008 Dodge Ram 1500 Truck Rear Performance Cross Drilled & Slotted Zinc Coated Brake Pad & Rotor Kit Premium Posi Semi-Metallic (excluding SRT-10 & Mega Cab)
  • 2009-2010 Dodge Ram 1500 Truck Brake Pad & Rotor Kit Rear Performance Cross Drilled & Slotted Zinc Coated Premium Posi Semi-Metallic
  • 2011-2013 Ram 1500 Truck Rear Performance Cross Drilled & Slotted Zinc Coated Brake Pad & Rotor Kit Premium Posi Semi-Metallic
cbo
My main question was, what changed from 2014+ on these trucks that will not allow these to work?
Graygoose
Indecisive Car Owner
Oklahoma
Convert, for now.
small
They probably will fit, but Tony can verify. They look good!
1ATony
1ATony
hemi
If you guys would would like to reply back with the year and series of your Ram trucks, I can post a link for you to the brake section on our website for your truck.
Tony
1ATony
1ATony
hemi
ttt
