- Mar 15, 2013
- 1,619
- 262
- 2013
- A shiny one
Newly reduced prices on two very popular Adam's products - kits including these items will be updated to reflect the new prices shortly. Enjoy!
ADAM'S GLASS SEALANT
Was $19.95 NOW ONLY $14.95
No one likes doing windows, but with Adam's Glass Sealant getting your windshield perfect will be so easy that it might just be your favorite part of cleaning your car!
Our super concentrated Adam's Glass Sealant comes in a 4oz pour top bottle of super concentrated optical sealant and makes all your windows super slick. By creating a non-stick surface on your glass water will bead up and simply roll away, working so effectively that rain will simply blow off your glass at normal highway driving speeds without the use of your windshield wipers. Used in conjunction with our Adam's Glass Cleaner and Adam's Microfiber Glass Cleaning Towel your windows will stay cleaner for longer and look clearer than ever before.
One bottle contains enough of our powerful sealant to treat all the glass on all your cars and you might even have enough left over to do your shower doors!
ADAM'S WATERLESS WASH GALLONS
Was $39.95 NOW ONLY $29.95
Advanced emulsifiers and special lubricants make our Adam's Waterless Car Wash a safe and effective way to remove light surface dust and dirt without harming your clear coat. It's the perfect choice when your access to water is limited or you just want to conserve H20.
Your car doesn’t always need a full bath with soap and water. Light surface dust, finger prints, or other minor surface contamination can be easily and safely removed using Adam's Waterless Car Wash. It saves water and it's quicker than a traditional wash as well! It also prolongs your wax or sealant life by using a less invasive method to clean, it can also be used in direct sunlight.
Spray Adam's Waterless Car Wash on moderately dirty finish, wipe clean with Adam's Waterless Wash Waffle Towels. Special lubricants and wetting agents encapsulate dirt, making it easy to clean the paint without damage and without water.
How is it different than Detail Spray? Adam's Waterless Car Wash is a more effective cleaner, and has more lubricant designed to remove larger dirt particles without causing swirls. It also has no gloss enhancers, so it leaves your paint clean but not glossy. Follow Adam's Waterless Car Wash with Adam's Detail Spray to enhance the gloss!
