firebuff17
I have a PVC non heated steering wheel with NO audio controls. I have read several threads about steering wheel audio controls and heated steering wheels. Learned a lot. Had a few questions though as far as heating goes.
I have a leather wrapped heated with audio control wheel already. I have not changed the wheel yet. I looked at my steering column and I have the blue connector that's plugged into a dummy holder on top of the column.
The new wheel wire harness should be all set to plug into the new clock spring. Then that blue connector gets plugged into the back of the clock spring. Then plug the new dash switch in and I should be all set. Correct?
I think all I need is the correct clock spring and the switch for the dash. Is this correct?
Here is my VIN
1C6RR7KT1ES195770
Thank you.
Here is my VIN
1C6RR7KT1ES195770
Thank you.
