Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 1st Gen : 1981 - 1993 > General Discussions
General Discussions
1987 Dodge Ram
This is a discussion on 1987 Dodge Ram within the General Discussions forums, part of the 1st Gen : 1981 - 1993 category!
So I am about to get a 1987 Dodge Ram from my grandfather that has been sitting for about 8 ...
Like Tree5Likes
Reply
Old 11-27-2016, 09:44 PM   #1 (permalink)
Ram Year: 1987
Engine: ??
Default 1987 Dodge Ram
So I am about to get a 1987 Dodge Ram from my grandfather that has been sitting for about 8 years. The truck was in excellent condition before my grandfather's health declined. He always took very good care of his vehicles. What is the first steps, I figure of many, to get it up and running. Have a new battery already.
Sent from my SM-G935V using Tapatalk
Sponsored Ad
Register to remove this ad.
saxman2584 is offline   Reply With Quote
Old 11-27-2016, 09:47 PM   #2 (permalink)
Ram Year: 1991
Engine: 5.2 318 v8
Default
Drain the gas tank and put fresh gas in and put the new battery in and it should run.
d250 is offline   Reply With Quote
Old 11-27-2016, 09:48 PM   #3 (permalink)
Ram Year: 1987
Engine: ??
Default
What is the best way to drain the gas?
Old 11-27-2016, 09:53 PM   #4 (permalink)
MADDOG's Avatar
Super Moderator
Ram Year: 2017
Engine: Cummins 6.7L Turbo Diesel
Default
I'd drain any fuel in the truck and try some carb cleaner down the throat of the carb. Check the carb butterflies for proper operation. Give the throttle linkage a good spray down with WD40 or PB Blaster to free it up if it is froze in place.
Drain the engine oil, service the differential(s). New lube and filters. Check the transmission fluid and PS fluid and brake fluid levels. Eventually you'll want to flush and refill all those systems.
Pull the plugs and inspect them. I would expect you'll need a fresh set along with some new plug wires as well.
Check the coil connections. Check the connection at the starter and the main ground for corrosion.
Starter fluid is your friend for priming the carb when you are ready to start it up.
Lastly, have fun!!!
reek and saxman2584 like this.
__________________
MICHAEL
SUPER MODERATOR
2017 RAM LARAMIE CTD
MADDOG is offline   Reply With Quote
Old 11-27-2016, 09:55 PM   #5 (permalink)
MADDOG's Avatar
Super Moderator
Ram Year: 2017
Default
Dropping the tank is the best way. While you are at it you can add a fuel system/tank cleaner and remove all the old varnish and crap inside the tank.
Also, check the fuel line connections at the tank. That old hose is probably dried out and cracked. If so, it indicates any rubber fuel lines will need replaced.
__________________
MICHAEL
SUPER MODERATOR
Old 11-28-2016, 02:55 AM   #6 (permalink)
crazzywolfie's Avatar
Ram Year: 81 93
Engine: 5.2
Default
i wouldn't worry about draining the tank or anything like that yet. check fluid/oil levers and then try starting it with some brake cleaner or any flammable oils in spray cans. the truck may start and possibly run on the gas that is still in it. once you get it running then go from there. check the brakes and brake lines for rust since the brakes are important. the rest is not too important. you can inspect and replace other stuff as you go.
RonJon '06 likes this.
crazzywolfie is offline   Reply With Quote
Old 11-28-2016, 12:11 PM   #7 (permalink)
Ram Year: 81 93
Engine: 5.2
Default
i am kind of surprised John did give us some of his wisdom. he has lots of experience firing up older vehicles that not run in a while. here is his trucks thread that he started. hopefully even just the first post will give you some hope that things are really not as bad as people make things seem.
My Power Ram 350
__________________
81 dodge d150 custom long box 318 670CFM Holley Street Avenger Carb
89 RamCharger 4x4 318/727/3.21 on 33's
93 ramcharger 318 FI 2wd
Old 11-28-2016, 12:42 PM   #8 (permalink)
RonJon '06's Avatar
Ram Year: 2006, 1985
Engine: 5.7, 360
Default
That's because I thought you guys covered it pretty well lol.
My '85 started right up and ran fine with the 20 year old gas that was in the tank. The only thing I'd add is change the fuel filter after a day or two then again after you put some miles on it. It seems to me that the brakes suffer the most from sitting idle.
saxman2584 likes this.
__________________
2006 | 1500 | MCSB | 4x4 | Built 5.7L Hemi
Forged Internals, Edge 2600, HD Trans cooler, JBA Shorties
1985 | W350 | RCLB | 360 | Dana 44/60, Firestone Ride-Rite Airbags
RonJon '06 is offline   Reply With Quote
Old 11-28-2016, 12:47 PM   #9 (permalink)
Ram Year: 1987
Engine: ??
Default
Cool thanks for the tips... headed back home to work on it in 2 weeks. Will keep y'all updated!
Old 11-28-2016, 12:52 PM   #10 (permalink)
Ram Year: 81 93
Engine: 5.2
Default
good luck and if you have any question just ask. someone is bound to know
haha ya. we did cover quite a bit but i figure there might have been something missed. i know you didn't fire up every vehicle from your dads place but i know you did a few and almost all the ones you tried fired up. they definitely don't make gas the same as they use to lol
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Advice on 1987 W250 build. MoparKing318 Member Trucks 2 05-31-2016 08:22 PM
03 dodge 5.9 cummins into an 07 dodge dcberry05 3rd Gen DIY 7 07-29-2015 01:43 PM
electrical issue on 1987 w100 Moparkid Audio & Electronics 2 04-18-2015 08:26 PM
Lifting 1987 Ramcharger Correctly dennisonwj General Discussions 1 07-07-2014 07:39 PM
1987 W150 318 -- No headers available? blastmagazine Engine & Performance 10 10-29-2013 01:14 AM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
