Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 1st Gen : 1981 - 1993 > General Discussions
General Discussions
318 exhaust manifold interchange
This is a discussion on 318 exhaust manifold interchange within the General Discussions forums, part of the 1st Gen : 1981 - 1993 category!
I have a 1986 dodge ram w250 4x4. Will the exhaust manifolds from a 60s model truck work on my ...
Like Tree1Likes
  • 1 Post By crazzywolfie
Reply
Old 09-29-2016, 03:22 AM   #1 (permalink)
Samueltdt's Avatar
Ram Year: 198;
Engine: 31_
Default 318 exhaust manifold interchange
I have a 1986 dodge ram w250 4x4. Will the exhaust manifolds from a 60s model truck work on my truck?
Sponsored Ad
Register to remove this ad.
Samueltdt is offline   Reply With Quote
Old 09-29-2016, 05:36 AM   #2 (permalink)
RamV10's Avatar
Ram Year: 1999
Engine: V10
Default
Weren't the 60s 318s a completely different motor?
__________________
1999 RAM V-10 4x4
2016 KIA SPORTAGE AWD
1973 GALAXIE 500 2dr Hardtop
RamV10 is offline   Reply With Quote
Old 09-29-2016, 09:16 AM   #3 (permalink)
Jimmy68's Avatar
Ram Year: 2001
Engine: 5.2L Magnum
Default
Manifolds off a Poly 318 will not fit a LA 318. But Magnum 318 manifolds will fit the LA and are a better manifold.
But Headers are cheap and are best anyway.
__________________
I've done more stupid sh#t as an adult than I ever did as a kid.
Trudeau & the NDP.
daylight savings. Leave the clocks alone.
NO TO BILL 6.
Jimmy68 is online now   Reply With Quote
Old 09-29-2016, 11:13 AM   #4 (permalink)
Samueltdt's Avatar
Ram Year: 198;
Engine: 31_
Default
I'm sorry. I'm new to the dodge truck. I don't understand LA and all others. I just need to know will they fit or not? Or can you explain a little better.I've tried to look it up on the internet. You just can't get answers like you used to.
Old 09-29-2016, 12:14 PM   #5 (permalink)
crazzywolfie's Avatar
Ram Year: 81 93
Engine: 5.2
Default
what year manifolds are you hoping to use? they started using the LA engine in 64 so there is a small chance they might work but it should really not be too hard to track down some manifolds for it. any 72-91 ram truck or van with a 318/360 should have manifolds that fit. they are also interchangeable between left and right so it really don't matter which side you get them off.
Jimmy68 likes this.
__________________
81 dodge d150 custom long box 318 670CFM Holley Street Avenger Carb
89 RamCharger 4x4 318/727/3.21 on 33's
93 ramcharger 318 FI 2wd
crazzywolfie is online now   Reply With Quote
Old 09-29-2016, 09:52 PM   #6 (permalink)
Jimmy68's Avatar
Ram Year: 2001
Engine: 5.2L Magnum
Default
To add confusion they were still running the Poly in 66. So you do need to know what engine your gleeming parts off of.
The Poly engine ran from 1955-1966/67.
The LA engine ran from 1964-2002/2003.
A lot of parts interchange between the 1962 to 1966 polyspherical A 318 engine and the LA series of Mopar motors (318, 273, 340, 360), including:
Thermostat
Thermostat housing
Internally balanced 273-318-340 harmonic balancers
Valve springs, retainers and keepers
Main bearings (NOT 360 though)
Rod bearings
Crankshafts (reground 360's included)
Flywheel
Starter, both standard and high torque
318 LA ring set
timing chain and sprocket
fuel pump
oil pump
oil pan (not 360) “The 360 front and rear seal/front timing cover is bigger than those of the 273/318LA/340 to accommodate the larger main bearings.”
distributor pump drive gear
distributor, standard points or electronic
__________________
Trudeau & the NDP.
NO TO BILL 6.
Old 09-29-2016, 11:49 PM   #7 (permalink)
Ram Year: 81 93
Engine: 5.2
Default
that is why i asked what year truck he is wanting to take the manifolds off of.
if it was my vehicle i would just find the right manifold. they used the same parts for 20 years and it is not a super common part to fail so they are easy to find. i got 3 spares even tho i will probably never used them.
__________________
Old 09-30-2016, 09:04 AM   #8 (permalink)
Jimmy68's Avatar
Ram Year: 2001
Engine: 5.2L Magnum
Default
Ya. Stock sucky manifolds. Damn near find them laying on the side of the road. I've Got a pair. Maybe more.
__________________
Trudeau & the NDP.
NO TO BILL 6.
Old 12-09-2016, 02:39 PM   #9 (permalink)
Sniper X's Avatar
Ram Year: 1991
Engine: 318
Default
Any junkyard will have many sets that will work.
__________________
Resistance is not futile, it is voltage divided by current.
Sniper X is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Exhaust manifold bolts mattmid101 Engine & Performance 4 06-22-2015 08:05 PM
Exhaust manifold? Tolson93 Engine & Performance 73 05-13-2015 08:59 PM
Exhaust Manifold Suggestion? Steel Engine & Performance 2 11-27-2014 10:49 AM
Exhaust Manifold Leak Ramsfan78 Engine & Performance 13 05-23-2014 12:26 AM
CTD exhaust manifold ramhunter9 For Sale 1 01-31-2012 06:46 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
