ray hall
- Jan 28, 2014
- 35
- 2
- 1983
- 225 slant six
I have an 85 dodge w150 I swapped the slant six out with a 360. I removed the lean burn and hooked up a 4 pin set up. My problem is I bough a resistor for an 85 it was a 4 terminal and I put it on with a stock coil. And it wouldn't start unless I ran a 12 volt jumper wire. Once it started it ran great until u turned the 12 volts off then it missed out real bad. So I checked the voltage. It had 3.57volts coming out of the resistor and the resistor was 5.2 ohms. I started looking at diagrams for that set up and it showed to have a 1.2 ohm resistor which I couldn't find. So I found that the accel super stock coil had a 1.4 internal resistor so I took the resistor off and put that coil on and it ran great for about 20 minutes then it fried the coil. So my question to you guys is what coil and resistor do I need to put on this truck so I don't have any problems. I greatly appriciate your input
