Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 1st Gen : 1981 - 1993 > General Discussions
General Discussions
65 Deluxe fire truck
This is a discussion on 65 Deluxe fire truck within the General Discussions forums, part of the 1st Gen : 1981 - 1993 category!
I have posted up in the introduction section and I thought id start a build thread so here goes .. ...
Reply
Old 01-03-2017, 03:07 PM   #1 (permalink)
Ram Year: 1981
Engine: 5.2
Default 65 Deluxe fire truck
I was offered this truck in a bit of a deal recently in exchange for some work and so far I'm quite impressed .
I should probably point out that I am not looking to do a full on build and am just going to have a bit of fun . I already have too many big projects which I'm happy to share if anyone is interested .
So far I have started taking all of the fire related stickers off and have begun flating back the original red paint which is coming up creating a nice patina which is what I'm after as I don't want to paint it - I own a classic car restorers here in the UK so have the ability but not the desire with this one .
The fire related stuff in the back has been removed but I will keep the lights etc .
Plans are to get all the paint polished up and tidy up the bumpers and a bit of rust , get some new wheels and tyres or at least some bigger tyres and then just tidy up the interior , I might well try and get a pair of Jaguar XJ6 rear seats as they are plentiful and cheep here .
Mechanically its pretty sound apart from the power steering pump which judders and the window washers and it needs a good service and some fresh fuel as its been sat for about 7 years .
I keep the pictures and updates going and I'm sure there will be a few silly questions as Im a novice at American iron .
Regards Jon
Sponsored Ad
Register to remove this ad.
65deluxe is offline   Reply With Quote
Old 01-03-2017, 03:50 PM   #2 (permalink)
MADDOG's Avatar
Super Moderator
Ram Year: 2017
Engine: Cummins 6.7L Turbo Diesel
Default
I like it, Jon! You don't see too many full sized crew cabs of that vintage.
Looking forward to your progress on this beast!
__________________
MICHAEL
SUPER MODERATOR
2017 RAM LARAMIE CTD
MADDOG is online now   Reply With Quote
Old 01-03-2017, 07:16 PM   #3 (permalink)
crazzywolfie's Avatar
Ram Year: 81 93
Engine: 5.2
Default
welcome. looks like you got a pretty cool project. i have always wanted a crew cab but just haven't found one for sale at the right time for me.
i don't know if i would worry about the power steering pump too much as long as it is not effecting the steering. generally the pumps on these things are pretty tough.
__________________
81 dodge d150 custom long box 318 670CFM Holley Street Avenger Carb
89 RamCharger 4x4 318/727/3.21 on 33's
93 ramcharger 318 FI 2wd
crazzywolfie is offline   Reply With Quote
Old 01-04-2017, 12:59 PM   #4 (permalink)
Sniper X's Avatar
Ram Year: 1991
Engine: 318
Default
I love it! I'd also love to find one of the early first gen crew cab 4x4s for myself. Even a 4x2 would be great.
__________________
Resistance is not futile, it is voltage divided by current.
Sniper X is offline   Reply With Quote
Old 01-04-2017, 02:24 PM   #5 (permalink)
Ram Year: 1981
Engine: 5.2
Default
Thanks for the replies .
I'm going to empty the fluid out the pump etc and refill first as it's been stood for years so my we'll be a bit gloopy .
It's certainly a rare beast over here in uk and is already attracting admirers in the corner of the workshop
Old 01-04-2017, 02:35 PM   #6 (permalink)
Ram Year: 81 93
Engine: 5.2
Default
it is actually pretty easy to flush the power steering system if you decide to do it yourself. you just have jack up the front axle, disconnect the return line from the pump and run it into a container. then you just have to fire up the truck and turn the steering back and forth lock to lock while keeping the reservoir topped up. should flush out the system for the most part.
__________________
Old 01-09-2017, 02:18 PM   #7 (permalink)
Ram Year: 1981
Engine: 5.2
Default
Been looking into the truck a bit today - managed to check vin number which revealed it's an 81 with 5.2 engine with 2 barrel carb and 8001-9000 lb weight - and made in Warren Michigan .
Mileage is showing as 58000 which being a fire truck and it's overall condition I believe is probably correct
Good news all round
Old 01-15-2017, 06:22 AM   #8 (permalink)
Ram Year: 1981
Engine: 5.2
Default
I managed to get the exhaust sorted on Friday - Replaced the back pipe with a custom made one incorporating a 24 inch cherry bomb - so it now makes a much better noise .
I also sorted the wash wipes for the front screen , the switch was shot so I used one in the dash for the multitude of lights on the top .
The slightly worrying thing is the power steering , which having followed some advise on here , I disconnected the return to the pump and basically bled it whist topping it up .
Lots of nasty brown rubbish came out and off the floor the wheels turned perfectly . However when I put it back on the ground I still had the judder . On closer inspection the pulley on the front of the pump was actually slowing down when it juddered , so I changed the belt to see if that helped and I now have a loud belt squeak as i turn the wheel so my thoughts are the pump is shot . however as it sat for so long i will take it for MOT and maybe it will all loosen up under use . ........ We can hope ...
If not it will need a new pump and they are hard to find over here , so maybe asking a favour ;-0
Anyway , I managed to get a picture or 2 now the hoses and water containers are off and most of the stickers
Onwards and upwards
Old 01-15-2017, 10:19 AM   #9 (permalink)
Ram Year: 81 93
Engine: 5.2
Default
looks good. are you sure you got the belt on the power steering is tight enough. i know the bracket that are used on your truck can be a bit of a pain to adjust. i think i usually end up having to put a pipe on my 1/2" drive to put the proper amount of tension on the power steering belt.
__________________
Old 01-15-2017, 10:46 AM   #10 (permalink)
RonJon '06's Avatar
Ram Year: 2006, 1985
Engine: 5.7, 360
Default
Nice truck and pretty low miles, looks like you're making good progress. I'd make sure the belt on the power steering pump is tight like Matt suggested. I've never done it before but if the pump ends up being bad and they're hard to find where you live you could rebuild it.
__________________
2006 | 1500 | MCSB | 4x4 | Built 5.7L Hemi
Forged Internals, Edge 2600, HD Trans cooler, JBA Shorties
1985 | W350 | RCLB | 360 | Dana 44/60, Firestone Ride-Rite Airbags
RonJon '06 is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Noise makes me wanna set truck on fire GreenGoblin General Discussions 9 11-02-2016 05:59 AM
GlOcKnRaM's "mini fire truck" build GlOcKnRaM Member Trucks 388 04-10-2016 10:51 AM
truck cranks but wont attempt to fire dionisi58 Engine & Performance 0 05-18-2014 01:29 PM
Truck caught fire.. Fishingking General Discussion 13 06-20-2013 06:20 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
