Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 1st Gen : 1981 - 1993 > General Discussions
General Discussions
85 W150 intermittent heater issue
This is a discussion on 85 W150 intermittent heater issue within the General Discussions forums, part of the 1st Gen : 1981 - 1993 category!
hahaha ya i could understand that. i don't know much about repairing the systems but i would guess it requires ...
Reply
Old 01-20-2017, 08:57 PM   #21 (permalink)
crazzywolfie's Avatar
Ram Year: 81 93
Engine: 5.2
Default
hahaha ya i could understand that. i don't know much about repairing the systems but i would guess it requires replacing pretty much all the seals in the system and recharging it if that is the issue with yours.
Sponsored Ad
Register to remove this ad.
__________________
81 dodge d150 custom long box 318 670CFM Holley Street Avenger Carb
89 RamCharger 4x4 318/727/3.21 on 33's
93 ramcharger 318 FI 2wd
crazzywolfie is offline   Reply With Quote
Old 01-21-2017, 05:14 PM   #22 (permalink)
Brucecmc's Avatar
Ram Year: 1985 Power Ram W-150
Engine: 318 V8 5.2L
Default
Wolfe, do I pop the fuse out and check across those terminals ??
Brucecmc is offline   Reply With Quote
Old 01-21-2017, 05:18 PM   #23 (permalink)
Ram Year: 81 93
Engine: 5.2
Default
popping the fuse out might make it easy to get a good reading. 1 side or the other should have 12v with the key in the run position.
__________________
Old 01-21-2017, 05:30 PM   #24 (permalink)
Brucecmc's Avatar
Engine: 318 V8 5.2L
Default
So it doesn't skew the potential problem by removing the fuse, to check across the fuse terminals.
Old 01-21-2017, 05:49 PM   #25 (permalink)
Brucecmc's Avatar
Engine: 318 V8 5.2L
Default
Good voltage at the fuse panel. I checked at the blower motor resistor, seems one terminal had 5v and the other 12v. And then there was a single terminal, don't know what it was (see pic)
Old 01-21-2017, 06:19 PM   #26 (permalink)
Brucecmc's Avatar
Engine: 318 V8 5.2L
Default
Well that's the resistor. I checked at the connector to this. Like dsexpress said the other day, it might be this sucker. Gonna replace it tomorrow (had to order) and see if it is so.
Old 01-21-2017, 06:22 PM   #27 (permalink)
Ram Year: 81 93
Engine: 5.2
Default
do you know what color the wires were that had power? you can try pulling it out to see if there is any issues with it.
__________________
Old 01-21-2017, 06:41 PM   #28 (permalink)
Brucecmc's Avatar
Engine: 318 V8 5.2L
Default
I don't know. I was just excited there was power on that side of the resistor.
Old 01-22-2017, 12:56 AM   #29 (permalink)
Ram Year: 2014
Engine: Hemi 5.7
Default
It could be a bad fan switch. I have had many burn out (some melted some). I always grabbed a couple when junkyarding.
Stewart is offline   Reply With Quote
Old 01-22-2017, 09:04 AM   #30 (permalink)
Brucecmc's Avatar
Engine: 318 V8 5.2L
Default
Wolfie,
You asked which pairs had what voltage. Hers is a pic.
The white/blue are the ones that had 5v
The brown/dark green had 12v
And that single green had nothing. But possibly I did t have it grounded well enuf when I took the reading ?
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Intermittent starting issue SGTGunner General Discussions 0 02-19-2016 01:34 PM
Intermittent starting issue Express SN95 General Discussions 4 01-04-2016 02:40 AM
Intermittent starting issue Ohioguy1966 Audio & Electronics 5 11-14-2015 04:23 PM
2007 overheating/heater intermittent problem mrjimmydale General Discussions 5 11-30-2013 07:20 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
