You can pull your own build sheets on the Dodge site with your VIN. Click the link below and go to "Equipment Listing" on the left. It will generate a PDF with your build info.
Tried your suggestions and apparently my truck is too old to look up. It's a 91 ram 2500 cummins 4x4 and am trying to get the info on the rear axle. If it's a dana 60? limited slip? Also wanting to add disc brakes. May have to jack up the rear end and check tire rotation for limited slip or open...
have you looked for a sticker under the hood? did you try your local dealer because they should still be able to look up your build sheet. i had them look up my 91's build sheet once. i also had them look up my 93's build sheet.
