Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 1st Gen : 1981 - 1993 > General Discussions
General Discussions
Gear Ratio mismatched
This is a discussion on Gear Ratio mismatched within the General Discussions forums, part of the 1st Gen : 1981 - 1993 category!
My first ever thread, so I hope it's a good one. I'm a teenager who has a fair bit of ...
Reply
Old 10-23-2016, 12:38 AM   #1 (permalink)
Walter Joy's Avatar
Ram Year: 1989
Engine: 5.9L (360) TBI V8
Default Gear Ratio mismatched
My first ever thread, so I hope it's a good one. I'm a teenager who has a fair bit of knowledge of mechanics and cars, and has been gifted with a 1989 Dodge W250 that has been in the family since 1992. I have just started working on the truck this past week with my family in order to get it on the road for me to go to school and work. Today we decided to put some new RTV on the front differential because it seemed like it was leaking. When we took the cover off I found the tag, and discovered the front axle, a Spicer 44-8F 3500lb, has 3.54:1 gearing. Now I had remembered looking at the build sheet and seeing it was supposed to have 4.10:1 gears. So I checked the rear tag (Spicer 60HD 5800lb) and saw it had a 4.10 in it. Is there supposed to be that much of a difference between front and rear? The driveline is a 360 V8 (throttle body) with a 727 Torqueflite and an NPG241 transfer case. I have read other forums across the web but they only discuss axles that are .01 or so off, not .56. Thank you so much
Sponsored Ad
Register to remove this ad.
Walter Joy is offline   Reply With Quote
Old 10-23-2016, 12:54 AM   #2 (permalink)
Ram Year: 2004
Engine: 6.4 HEMI
Default
That is too much of a difference.
Maybe one of the axles was replaced? Or maybe someone upgraded to 4:10's and did not change the tag?
You can check by jacking up each axle, rotate a tire and count how many times the drive shaft turns. 1 full rotation of the tire, count turns of drive shaft.
__________________
2004 Dodge RAM QC 4X4, 426 Hemi W/ Ported Big Valve Heads
DaKing is offline   Reply With Quote
Old 10-23-2016, 12:59 AM   #3 (permalink)
Walter Joy's Avatar
Ram Year: 1989
Default
I will try that the next time we have the front jacked up (replacing the brakes now). The build sheet said it should have 4.10 and I assume it means front and rear. Just seems odd. The build sheet also specified I had 12x2.5 rear drums but when we measured them (after buying all the stuff for new 2.5 drums) they were 3 inch. So somewhere there are things not lining up
Old 10-23-2016, 01:25 AM   #4 (permalink)
07MegaCabRam's Avatar
Ram Year: 2014
Engine: 6.7L CTD
Default
front and rear need to match.
__________________
::2014 Ram 2500 CTD 4x4 Crew Cab::
07MegaCabRam is offline   Reply With Quote
Old 10-23-2016, 01:30 AM   #5 (permalink)
Walter Joy's Avatar
Ram Year: 1989
Default
Yet the odd thing is it seems alright when in 4wd (or I think. The light doesn't come on so either it's blown or something else)
Old 10-23-2016, 10:02 AM   #6 (permalink)
Jimmy68's Avatar
Ram Year: 2001
Engine: 5.2L Magnum
Default
Take off your covers. Verify your gears. If you do not have a match set do not use 4x4 till you do. Be fine to drive and be fine to use 4x4 in the mud. Front will spin faster which actually will help. I'm talking deep mud, like a foot or more. Chances are as a daily driver your not abusing your truck like that anyway.
__________________
I've done more stupid sh#t as an adult than I ever did as a kid.
Trudeau & the NDP.
daylight savings. Leave the clocks alone.
NO TO BILL 6.
Jimmy68 is offline   Reply With Quote
Old 10-23-2016, 03:52 PM   #7 (permalink)
Ram Year: 2001 ram 3500
Engine: V10
Default
counting driveshaft revs has been kinda hit or miss for me, and tags can be swapped. But removing the covers and reading the numbers stamped on the ring gear or counting the teeth on the gears is foolproof.
Rustycowl69 is offline   Reply With Quote
Old 10-23-2016, 04:25 PM   #8 (permalink)
Walter Joy's Avatar
Ram Year: 1989
Default
Thanks. I bet it just is a mismatched tag (probably from factory too. Who knows). As dad was saying, he's driven the truck 300 miles round trip in 4wd during snow once and it hasn't blown up. So I would expect it to have done so between 1989 and now
Old 10-23-2016, 06:23 PM   #9 (permalink)
crazzywolfie's Avatar
Ram Year: 81 93
Engine: 5.2
Default
the drums are the same for both 2.5 and 3 inch wide shoes. also since you are doing the brakes and lines this would be a good opportunity to swap to 3" shoes and the larger 1-1/8" bore wheel cylinders. both should cost about the same as the smaller parts.
__________________
81 dodge d150 custom long box 318 670CFM Holley Street Avenger Carb
89 RamCharger 4x4 318/727/3.21 on 33's
93 ramcharger 318 FI 2wd
crazzywolfie is offline   Reply With Quote
Old 10-23-2016, 09:58 PM   #10 (permalink)
Walter Joy's Avatar
Ram Year: 1989
Default
Next time around. Right now I just want to get the truck on the road again after 10 years of it being idle (to put it in perspective, 3 or 4 years ago we took it on the road and the odometer rolled to 44,000 miles. Today it sits at 44,035 miles.)
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Gear Ratio Witch Engine & Performance 16 05-13-2016 07:08 PM
Gear ratio Alextapia Engine & Performance 10 10-02-2015 11:16 PM
gear ratio chris2565 Towing & Hauling 5 05-22-2015 12:21 AM
Gear ratio Kevin K Towing & Hauling 4 04-03-2015 09:30 AM
gear ratio Izzyb47 Engine & Performance 2 02-06-2015 09:10 AM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
