Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 1st Gen : 1981 - 1993 > General Discussions
General Discussions
Help diagnosing problem with truck running
This is a discussion on Help diagnosing problem with truck running within the General Discussions forums, part of the 1st Gen : 1981 - 1993 category!
Hey guys i have a 92 w150 318. About 6 weeks ago my truck started having this problem where it ...
Reply
Old 12-08-2016, 07:59 PM   #1 (permalink)
Ram Year: 1992
Engine: 318
Question Help diagnosing problem with truck running
About 6 weeks ago my truck started having this problem where it would randomly die while driving.
Sometimes after dying the truck will start right back no problem and i wont have a problem with it for a couple weeks.
Other times the truck will fire up for a second and then die again, die as soon as i put it in gear or it will crank with no start.
when it cranks with no start sometimes it'll start after a couple minutes of sitting and other times it'll have to sit much longer (3 or 4 weeks ago it took about 90min of sitting to start up again)
Today I learned how to read the trouble codes on it and i got codes 12,33,37,52,55. (I don't know 100% if these are the correct codes as i had to have someone else read them for me so ill leave a link to a video of it cycling through the codes below)
from what I've read i can disregard codes 12 and 55.
i also believe i can ignore code 33 as it has something to do with the A/C circuit and my truck came from the factory without A/C.
I think the cause of the problem lays in code 52.
I know code 52 is for the engine running too rich but i read on another form a faulty ignition component could be tripping the code.
What makes me think this is the cause of the problem is my ignition seems pretty worn out (i can start the truck without a key and pull out the key while its running, although the ignition lock still works)
I'm hoping someone more experienced can give me some insight here.
I've never had to deal with something like this and i want to have some idea what I'm doing before i go tearing into my truck.
link to code cycling video: https://www.youtube.com/watch?v=LIYoHQj4Fis
sorry if the formatting is shitty this is my first post.
Sponsored Ad
Register to remove this ad.
kylelie22 is offline   Reply With Quote
Old 12-08-2016, 11:39 PM   #2 (permalink)
Sniper X's Avatar
Ram Year: 1991
Engine: 318
Default
This sounds exactly like what heppened to mine shortly after I got it. It turned out to be the hall effects sensor or what many refer to as the ignition module in the distributor. It only took about 15 minutes to change out, and I seem to remeber the good premium one I got from NAPA was only about 60 dollars or less. However, this is also what the faulty going out fuel pump did to me for months off and on before it went out. Your truck is old enough now to just do the ignition in the distributor first anyway just to make sure it doesn't fail at the worst time and if that isn't it it is probably the fuel pump.
__________________
Resistance is not futile, it is voltage divided by current.
Sniper X is offline   Reply With Quote
Old 12-08-2016, 11:45 PM   #3 (permalink)
Sniper X's Avatar
Ram Year: 1991
Engine: 318
Default
Here it is from Napa
https://www.napaonline.com/napa/en/p...827_0239467558
You remove the dizzy cap, there are two screws both allen head cap scrrews, one on each side one in front and one in back 180 degrees from each other. Remove them, take the old one out, put the new one in , and replace the screws tightly. Put the dizzy cap back on and fire her up!
__________________
Old 12-14-2016, 01:14 AM   #4 (permalink)
Sniper X's Avatar
Ram Year: 1991
Engine: 318
Default
Hello?
__________________
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
2014 Ram running/headlight problem kevo62 Audio & Electronics 1 07-12-2016 11:06 AM
1984 d150 running problem Chad ring Tech Info 5 08-12-2015 11:06 PM
Diagnosing Your Paint Issue Surf City Garage Detailing 0 07-28-2014 06:44 PM
2001 problem staying running micheal41 Engine & Performance 1 12-06-2013 02:51 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
