Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 1st Gen : 1981 - 1993 > General Discussions
General Discussions
Horn doesn't work 1985 power ram W150
This is a discussion on Horn doesn't work 1985 power ram W150 within the General Discussions forums, part of the 1st Gen : 1981 - 1993 category!
i just noted, none of the gauges work either when I place the ignition switch in either the start or ...
Reply
Old 11-23-2016, 02:10 PM   #11 (permalink)
Brucecmc's Avatar
Ram Year: 1985 Power Ram W-150
Engine: 318 V8 5.2L
Default
i just noted, none of the gauges work either when I place the ignition switch in either the start or run positions...I kinda know what th fusable link is, but I'm thinking the fuse box is going to say "fuseable link" ???
Sponsored Ad
Register to remove this ad.
Brucecmc is offline   Reply With Quote
Old 11-23-2016, 02:12 PM   #12 (permalink)
Brucecmc's Avatar
Engine: 318 V8 5.2L
Default
would that also cause this condition i'm talking about with the truck running in the start position, but when releasing, it dies? or is that something else entirely?
Old 11-23-2016, 04:05 PM   #13 (permalink)
Brucecmc's Avatar
Engine: 318 V8 5.2L
Default
Well, horn still doesn't work, but the truck starts again. Weird. I stepped thru checking the availability of power at the fusible link. Hot on both sides. One of the links has been spiced off. But it checked good also. Moved up to the ballast resistor. Turned key to run position, and no power on either terminal. Thought maybe my test light wasn't grounded well, moved it around a little. Still nothing. Tested the light with the pos side of battery. Wiggled it around a little and at first got nothing. Wiggled the ground on light and hit the pos batt term and all of a sudden the enterior cab alarm started blaring. Jumped in and she cranked right up. Wtf. Gremlins?
Old 11-23-2016, 04:07 PM   #14 (permalink)
Brucecmc's Avatar
Engine: 318 V8 5.2L
Default
Worse than gremlins. 32 year old loose connection somewhere !!!!! Ughgh. Haven't seen the last of this.
Old 11-23-2016, 05:08 PM   #15 (permalink)
crazzywolfie's Avatar
Ram Year: 81 93
Engine: 5.2
Default
i know all about the gremlins. my 81 has them but i have hunted them down for now. the big thing is just properly fixing them eventually. under my hood looks like a electrical nightmare to anyone other than me.
did you install the alarm in the truck? could possibly be a bad connection at the ballast resister or somewhere and poking around under the hood fixed it. just keep some wire on had just in case it quits working. when in doubt just run a new power wire to the ballast resister from the battery. wouldn't be the first time i have had to do something like that. next time it acts up i would still check the fuses in the cab for power with the key on to see which may or may not be getting power. you could still have a failing fusible link.
__________________
81 dodge d150 custom long box 318 670CFM Holley Street Avenger Carb
89 RamCharger 4x4 318/727/3.21 on 33's
93 ramcharger 318 FI 2wd
crazzywolfie is online now   Reply With Quote
Old 11-23-2016, 06:48 PM   #16 (permalink)
Brucecmc's Avatar
Engine: 318 V8 5.2L
Default Horn don't
Thanks wolfie
Appreciate ur responses. And that fusible link appeared good. And I agree, under the hood is like looking at octopi having sex. Really old octopi.
My cousin who helped me trace some told me "don't go too far from home without tools and spare parts". Lol.
I gotta circle back in this thread to see what was said about the horn and how to chase that down. I kinda highjacked this thread to beg info about the bigger problem. Doh!!!
Thanks again.
Old 11-23-2016, 07:14 PM   #17 (permalink)
Ram Year: 81 93
Engine: 5.2
Default
hahaha. i practically know how to hotwire almost everything on these trucks.
i would pull the horn relay and make a jumper accross 2 of the terminals to see if you can get the horn working from inside the cab. if a jumper cable make the horn work from inside the cab then your issue is most likely a bad relay.
__________________
Old 11-23-2016, 09:04 PM   #18 (permalink)
Brucecmc's Avatar
Engine: 318 V8 5.2L
Default Horn don't work
Yea, that relay is next on the list to isolate out.
I'm a fledgling at this and by no means am I a mech. So, I rely on this kinda info. I'll keep ya posted in the progress of the horn.
Thanks Brutha.
Old 11-23-2016, 09:12 PM   #19 (permalink)
Ram Year: 81 93
Engine: 5.2
Default
no problem. i end up helping my dad with the same stuff. he understand the basic on off switches and how to use the a test light but trouble shooting is not his best area. i am the one who usually fixes electrical issues for him. i wish he was driving a dodge since i know them in and out but he has a ford so i am always learning something new with each issue.
__________________
Old 11-24-2016, 02:05 PM   #20 (permalink)
Brucecmc's Avatar
Engine: 318 V8 5.2L
Default HORN WORKS!!!!!! 1985 power ram W150
After testing this, testing that, checking wiring, blah blah, turned out to be the horn relay!!!! She honks like a dream now.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
1985 W150 fuel line too close to exhaust? Vapor lock? Fire? I_chew_big_red Engine & Performance 7 05-18-2016 09:26 AM
1985 W150 fuel line too close to exhaust? Vapor lock? Fire? I_chew_big_red Engine & Performance 0 05-12-2016 10:12 AM
1985 W150 repairs. Am I getting ripped off? I_chew_big_red General Discussions 3 05-07-2016 07:24 PM
1985 W150 Power Ram Deamer Member Trucks 10 04-14-2014 07:58 PM
1985 w150 acts like it runs out of gas when passing jcp dodge Engine & Performance 4 02-20-2013 12:19 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
