My 1976 project thread
dodge dude94
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
Don't know why, the overflow on my Ram is clean as a whistle. :hmm:
dodge dude94
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
So I've put 2 qt of oil in this thing over about 200 mi. I know it leaks, but it doesn't smoke that bad and I DAMN well know it's not leaking 2 qt worth of oil.
Dafuq?
crazzywolfie
under the truck
that 1 low compression cylinder is probably burning it all up. did you ever to a wet compression test on that cylinder?
RonJon '06
Southern Minnesota
dodge dude94
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
Well, the cylinders were all pretty close and the ones on the drivers side were "okay" so that's what puzzles me. And no I didn't.
I think that's your "smoking gun" right there....cough...cough. ;)
Valve seals, piston rings, leaks......an overhaul might be the way to go. 2¢
ha-ha! :bleh:
Overhaul would be great. :( New rings, mild cam, rebuilt carb, shaved heads, etc....
crazzywolfie
under the truck
all it takes is 1 low compression cylinder to suck in and burn lots of oil. it may not always smoke like it but it is burning oil.
dodge dude94
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
I need do run the comp test again and seal my tester better I think.
dodge dude94
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
Yah, fo sho. I also need to replace my cooling hoses. :crazy:
<--- The laziness is strong with this one.
dodge dude94
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
Went and bought a couple stainless nuts and bolts of the exhaust coupler today. I have the feeling they might be too small.
What do you think, Crazzzzzzzzy?
They're 3/8 by 2 inches long. Here is where I'm concerned: the old nuts use a 11/16 socket and the bolt head is a 5/8. But the new ones are 9/16 for both.
Do I actually need 1/2in bolts?
dodge dude94
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
I've got a big block though, the manifolds ARE different.
Worst thing is I tear it all apart and they're wrong I guess. Got 3 other vehicles to use to drive to Lowes again. lol
dodge dude94
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
I did. lol The nut was 11/16s and the bolt head was 5/8s.
dodge dude94
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
Yeah, on and off. I was going to run a die over the bolt, but there are no threads exposed for me to do that. Bolt is *almost* too short for nut that's on there. lol
