So this is where I'm at on my lights.
After having to tear them apart and RTV EVERYTHING, I put them back together and started looking at mounting locations.
Knowing there were holes pre-drilled in the core supported, I had been thinking about mounting a bar behind the grille and mounting them there. When I got to thinking about it I decided with the nature of the grille design, it would be a ***** of a pain to work with. I also decided that the lights would end up getting blocked out by at least one grille slat.
So I'm thinking one of two ways: somehow mounted to the top of the bumper or making a bracket that bolts to the core support and comes out of the grille there each light can mount.
Now, for the bumper mounted option, I am NOT, and WILL NOT, drill into my bumper as it's MINT 76 factory. I'm thinking some sort of deal that will clamp onto it, but I don't know what as I haven't gone to the hardware store yet.
Now, here are holes in the core support:
There are three holes, on each side of the support, all the same size, all evenly spaced. So I figure I might be able to use them to my advantage.
You can see the three holes here:
So what do you think? Bumper or grille?!
