Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 1st Gen : 1981 - 1993 > General Discussions
General Discussions
No lights and truck won't start
This is a discussion on No lights and truck won't start within the General Discussions forums, part of the 1st Gen : 1981 - 1993 category!
Hey Everyone, I have an '89 W150 318 auto. I've had this problem for quite a while and I have ...
Reply
Old 08-16-2016, 07:54 PM   #1 (permalink)
Ram Year: 1989 Power Ram and 2008 Ram Quad Cab
Engine: 318 and 5.7 Hemi
Default No lights and truck won't start
Hey Everyone,
I have an '89 W150 318 auto. I've had this problem for quite a while and I have pretty much exhausted myself trying to figure this thing out. A couple months ago I hopped in and started the truck. The radio cut off, the blower blew on high and the trailer brake lit up. After a few seconds of that the blower stopped and the trailer brake light went out. I still had no radio. Drove home without any problems that I knew of. After being home a couple hours I hopped in to go somewhere and the truck wouldn't start. I have no headlights, parking lights, taillights, dome light, underhood light etc. Checked all the fuses which were all good. When I turn the key, the fuel pump pumps, the oil light and maint lights are lit. The relay just clicks. Put in a new relay. Didn't help. I pulled the battery and swapped it from my Dart, checked all the cables and connections. Still didn't help. Pulled the starter, put in a new one and still no starting. I pulled the instrument cluster and checked the wiring there since the radio still didn't work. I didn't see anything abnormal. I'm all out of ideas of where to look. I'm kinda convinced my problems are some how related, just now sure how. I recently dug out my shop manual for the truck and may do some light reading before bed. Thanks in advance for any help. Later
Sponsored Ad
Register to remove this ad.
PowerRam89 is offline   Reply With Quote
Old 08-16-2016, 10:09 PM   #2 (permalink)
crazzywolfie's Avatar
Ram Year: 81 93
Engine: 5.2
Default
almost sounds like you have a blown fusible link or 2. they are on the drivers side fender
__________________
81 dodge d150 custom long box 318 670CFM Holley Street Avenger Carb
89 RamCharger 4x4 318/727/3.21 on 33's
93 ramcharger 318 FI 2wd
crazzywolfie is offline   Reply With Quote
Old 11-27-2016, 09:49 AM   #3 (permalink)
Brucecmc's Avatar
Ram Year: 1985 Power Ram W-150
Engine: 318 V8 5.2L
Default
Should have voltage on both sides of that fusible link. I ran into something similar. Poke the fat wire with test light, the poked the 4 individual wires with the test light. First time I ran across a "fusible link". If you're not familiar here is a pic (one of the links has been bypassed). The links say "fusible" on them
Brucecmc is offline   Reply With Quote
Old 11-27-2016, 09:50 AM   #4 (permalink)
Brucecmc's Avatar
Engine: 318 V8 5.2L
Default
Forgot pic. Here ya go
Old 11-27-2016, 11:22 AM   #5 (permalink)
Ram Year: 2015
Engine: 5.7hemi
Default
I had that problem on a 76 dodge p/u . it was the fire wall connector I removed it ,cleaned it (with battery disconnected) with a small brass brush then a little dielectric grease and reassembled no problems ever again electrically
as a side note I put a 400 engine with roadrunner heads and a 750 carb I don't remember all the details but the engine was built by a speed shop in tx, IT WAS QUICK when I registered it with Mi. DMV my lic plate was SL-076 TRUCK IS GONE I STILL HAVE THE PLATE regretfully Mi. winters took their toll on the truck and the plate
brianj
__________________
brianj tncruiser
ruby red express HEMI
living life in east tn and going
wherever my ram, ,explorer and motorhome take us
tncruiser is offline   Reply With Quote
Old 12-03-2016, 09:11 AM   #6 (permalink)
Default
Hey Everyone,
Thanks for the input. I have an update for you guys. I found my problem, wasn't the fusible links, but it put me in the right location to find the problem. The black 6 gauge wire that comes off the positive of the battery rubbed on the inner fender. It had been corroding for some time. It broke apart not allowing the truck to start and when it made contact with the inner fender it blew out my low beam on the headlights, the dome light, the underhood light and one taillight . Thanks for the help and it's great having my old Dodge up and running again.
Old 12-08-2016, 12:53 AM   #7 (permalink)
Sniper X's Avatar
Ram Year: 1991
Engine: 318
Default
Get rid of the fuseable links anyway! I do a mod to them but installing a set of fuese with holders in the same location. I use a 40A fuse for each. It has kept me from having many of the strange and now well known Dodge truck electrical problems.
__________________
Resistance is not futile, it is voltage divided by current.
Sniper X is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Engine Wont start. All panel and lights work duckewes Engine & Performance 5 08-18-2014 09:15 PM
Engine Wont start. All panel and lights work duckewes Tech Info 12 08-18-2014 07:41 PM
Won't Start - Lights Flashing J-Jaker Tech Info 1 05-02-2014 09:42 AM
2012 1500 sport wont start... throwing up lights and service 4wd MB1500SPRT Tech Info 4 02-05-2014 12:07 AM
Issues with 13 remote start and lights Gtsum27 Audio & Electronics 3 05-19-2013 04:16 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
