Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 1st Gen : 1981 - 1993 > General Discussions
General Discussions
Squids 88 thread
This is a discussion on Squids 88 thread within the General Discussions forums, part of the 1st Gen : 1981 - 1993 category!
Does it look like this? The pump is like 68 dollars and these are 69. From what I gather the ...
Like Tree3Likes
Reply
Old 12-13-2016, 02:02 AM   #11 (permalink)
Sniper X's Avatar
Ram Year: 1991
Engine: 318
Default
From what I gather the pump is in a velley in the bottom of the tank, the sender is this seperate deal.. Mine is a 1991 after the change to the integral unit they used for years even thru the second gen trucks use a pump like mine. I just did mine.
Sponsored Ad
Register to remove this ad.
__________________
Resistance is not futile, it is voltage divided by current.
Sniper X is offline   Reply With Quote
Old 12-13-2016, 08:47 AM   #12 (permalink)
Ram Year: 1988
Engine: 318 5.2
Default
I wish. No it's nothing like it. I'll have a pic up shortly. Weirdest thing I've ever seen.
3Squids is offline   Reply With Quote
Old 12-13-2016, 09:21 AM   #13 (permalink)
crazzywolfie's Avatar
Ram Year: 81 93
Engine: 5.2
Default
that looks like a ford part. this is what the sending unit looks like for a 88-90 truck. looking at it again makes wonder if you could possibly use the sending unit out of a new truck as long the round plat up to was the same diameter
__________________
81 dodge d150 custom long box 318 670CFM Holley Street Avenger Carb
89 RamCharger 4x4 318/727/3.21 on 33's
93 ramcharger 318 FI 2wd
crazzywolfie is online now   Reply With Quote
Old 12-13-2016, 07:09 PM   #14 (permalink)
Ram Year: 1988
Engine: 318 5.2
Default
Exactly what I got. However I wish mine was in that condition.
I've read that the newer ones are a different diameter and if you're going to swap it all to new style the best thing to do is get a tank and sending unit from a newer 90-93 truck. I'm going to soak this one in Evapo-Rust and see what happens. If she cleans up well I'll probably just keep it. Hell I already got a new pump and sock for it.
Rustycowl69 likes this.
Old 12-13-2016, 07:37 PM   #15 (permalink)
Ram Year: 81 93
Engine: 5.2
Default
ya i check that today. i still think you could make it work. you don't have to worry about the curly line holding fuel. it just has to press the sending unit down. the only thing that you might have issues with is the fuel sending unit. once you get some of the rust removed you may want to hook the sending unit back up to the truck and see if it is working or not. it would definitely suck to put it all back together and not have it work.
__________________
Old 12-13-2016, 08:35 PM   #16 (permalink)
Ram Year: 1988
Engine: 318 5.2
Default
Yea having the bed off would make it not such a pain to pull it back out but yes I plan on making sure the unit works before I get too far.
Old 12-13-2016, 08:49 PM   #17 (permalink)
Ram Year: 81 93
Engine: 5.2
Default
hopefully it works. if not you could possibly get a 90's jeep Cherokee fuel tank and modify it to work in a truck. i have considered putting one in my 81 but the jeep tank is too tall to look right since the back end of my truck sits pretty high. if your lowering your truck and building it for performance then it might be the better route. just so you have the weight sitting behind the axle instead of it hanging on the 1 side of the truck.
__________________
Old 12-14-2016, 12:25 AM   #18 (permalink)
Ram Year: 1988
Engine: 318 5.2
Default
Interesting. Never thought of that. Perhaps maybe even a fuel cell and a electric fuel pump with a pressure regulator?? I'm definitely not up to par on efi stuff. I know this TBI seems to be the most primitive form EFI but I still know little about it. I have always been a carb guy when it comes to my street cruisers and leave the new stuff for the grocery getters. But I do think I'd like to keep this one TBI rather then carb it.
Old 12-14-2016, 12:35 AM   #19 (permalink)
Ram Year: 81 93
Engine: 5.2
Default
i don't know how legal fuel cells are on street vehicles which is why i suggested a jeep fuel tank. it is plastic and it is approximately 32"x22"x12" which should fit between the framerails at the back nicely. the only thing is the one i got off a 96 had no return line so one would have to be added to make it work with TBI. as far as pressure regulators go you shouldn't need one. there is one on the TB. i think the TBI system only requires 15 PSI to run and everything else runs back to the tank.
__________________
Old 12-14-2016, 12:53 AM   #20 (permalink)
Ram Year: 1988
Engine: 318 5.2
Default
Good point about the cell. Definitely something I'm going to look into. If I could mount a stock style tank where the spare tire is and make it work with the throttle body then I'd be in good shape. Weight distribution plus getting rid of that terrible fuel pump assembly. Sounds good to me. I guess the filler hose may be an issue bit nothing I can't figure out.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Another mpg thread 2013sport General Discussions 31 03-31-2016 09:54 PM
Another 'will they fit' thread... Road King Exterior 2 02-09-2016 01:58 PM
WTF thread Stangshcky12 eBay & Craiglist Listings 230 12-19-2013 05:51 PM
Mod Thread BlackDiesel Member Trucks 19 08-28-2012 02:10 PM
my second thread qatarihombre General Discussions 8 11-16-2011 12:17 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
