Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 1st Gen : 1981 - 1993 > General Discussions
General Discussions
transfer case does not shift
This is a discussion on transfer case does not shift within the General Discussions forums, part of the 1st Gen : 1981 - 1993 category!
Hello.I have a 93 w250 that has been sitting for years and was left in 4low.It will not shift out ...
Reply
Old 09-13-2017, 11:23 PM   #1 (permalink)
Ram Year: 1993w250 94 1500
Engine: 5.2 5.9
Default transfer case does not shift
Hello.I have a 93 w250 that has been sitting for years and was left in 4low.It will not shift out of low,but the front axle disengages. It has good vacuum at one of the lines at the actuator on the transfer case. I changed the actuator and is still is stuck in low. Any ideas what could wrong. I should have said shifter goes forward and the front axle disengages(it's vacuum operated) but the transfer case stays in low and the light on the dash stays on.
Sponsored Ad
Register to remove this ad.
tud22 is offline   Reply With Quote
Old 09-14-2017, 07:10 PM   #2 (permalink)
crazzywolfie's Avatar
Ram Year: 81 93
Engine: 5.2
Default
you may have to really push on the shifter to get it out of 4low. 2hi/4 high and neutral are usually easy to shift in and out of but 4 low usually take a bit of force to get in and out of.
__________________
81 dodge d150 custom long box 318 670CFM Holley Street Avenger Carb
89 RamCharger 4x4 318/727/3.21 on 33's
93 ramcharger 318 FI 2wd
crazzywolfie is offline   Reply With Quote
Old 09-14-2017, 07:14 PM   #3 (permalink)
Ram Year: 2014
Engine: Hemi 5.7
Default
get it rolling slow 2-3 mph on a flat road, drop the truck into neutral and give that sifter and good shove forward. Give it some grunt the rolling and neutral should get the gears to break loose and let you get it out of 4low. even 4 high with the front hubs unlocked isnt perfect but better than granny gears.
WilliamS is offline   Reply With Quote
Old 09-14-2017, 09:43 PM   #4 (permalink)
Engine: 5.2 5.9
Default
thanks, I will give it a try this weekend
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Transfer case shift linkage JAMMAN Engine & Performance 1 01-06-2016 02:58 PM
4Wheel Drive Shift Rod to Transfer Case orangebrd72 Garage 0 09-04-2015 09:47 AM
manual shift transfer case sewardmark General Discussions 3 12-25-2013 11:29 PM
transfer case shift lever dinger General Discussions 9 03-27-2013 10:11 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
