Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 1st Gen : 1981 - 1993 > General Discussions
General Discussions
Weak horn sound
This is a discussion on Weak horn sound within the General Discussions forums, part of the 1st Gen : 1981 - 1993 category!
first time post. 1985 ram custom 100. It didn't pass state inspection, horn sound is very weak. I looked for ...
Reply
Old 11-11-2016, 09:48 AM   #1 (permalink)
Ram Year: 1985
Engine: slant 6
Default Weak horn sound
first time post. 1985 ram custom 100. It didn't pass state inspection, horn sound is very weak. I looked for a relay but couldn't find one. If I connect the horn directly to the battery the sound is normal. I thought about adding a switch just to get thru the inspection. Any help would be appreciated.
Sponsored Ad
Register to remove this ad.
Dan40 is offline   Reply With Quote
Old 11-11-2016, 10:04 AM   #2 (permalink)
crazzywolfie's Avatar
Ram Year: 81 93
Engine: 5.2
Default
the relay for the stock horn is under the dash in the fuse panel.
__________________
81 dodge d150 custom long box 318 670CFM Holley Street Avenger Carb
89 RamCharger 4x4 318/727/3.21 on 33's
93 ramcharger 318 FI 2wd
crazzywolfie is offline   Reply With Quote
Old 11-12-2016, 04:25 PM   #3 (permalink)
Ram Year: 1985
Engine: slant 6
Default relay switch
Thanks for the info. I put a new relay in and still the same problem. If I attach a jumper to the horn form the battery it works fine. If I fine the problem I will let yu know.
Old 11-12-2016, 04:37 PM   #4 (permalink)
Ram Year: 81 93
Engine: 5.2
Default
have you tried testing what the voltage is at the relay? you could possibly install a relay under the hood that is activated by the stock horn wire. a aftermarket relay would take less power to activate than the horn would use.
__________________
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
2014 Big Horn grinding sound Cuzncraig General Discussions 6 07-29-2016 10:11 PM
And still, weak heat... kdryan General Discussion 8 11-30-2015 03:02 PM
Update: 8.4AN_RA4_15_17_5_MY15, fixed weak SXM sound. RoadKing Audio & Electronics 8 07-23-2015 03:49 PM
How do I turn off horn sound when I press "Lock" button? Pandalerium Tech Info 10 12-05-2013 09:25 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
