Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 1st Gen : 1981 - 1993 > General Discussions
General Discussions
What starters fit a 1991 318 v8?
This is a discussion on What starters fit a 1991 318 v8? within the General Discussions forums, part of the 1st Gen : 1981 - 1993 category!
How does it look Sent from my iPhone using Tapatalk...
Reply
Old 02-12-2017, 11:09 AM   #21 (permalink)
Ram Year: 1991
Engine: 5.2 318 v8
Default
How does it look
Sponsored Ad
Register to remove this ad.
d250 is offline   Reply With Quote
Old 02-12-2017, 11:17 AM   #22 (permalink)
crazzywolfie's Avatar
Ram Year: 81 93
Engine: 5.2
Default
i was more so talking about the contact surface on the plunger. is it chewed up like the contact? if the plunger is barely making contact with the terminal that is probably why you are having issues.
__________________
81 dodge d150 custom long box 318 670CFM Holley Street Avenger Carb
89 RamCharger 4x4 318/727/3.21 on 33's
93 ramcharger 318 FI 2wd
crazzywolfie is offline   Reply With Quote
Old 02-12-2017, 11:20 AM   #23 (permalink)
Ram Year: 1991
Engine: 5.2 318 v8
Default
Old 02-12-2017, 12:00 PM   #24 (permalink)
Ram Year: 81 93
Engine: 5.2
Default
it looks like it is pretty chewed also. i am guessing between the chewed up contact and that there is probably enough material gone to stop the starter from working. if you got a rubber or plastic washer kicking around you could try shimming the 1 contact and see how it works. you just need to shim the contact enough that the plunger lands on a thicker section.
__________________
Old 02-12-2017, 02:25 PM   #25 (permalink)
Ram Year: 1991
Engine: 5.2 318 v8
Default
I tried putting a rubber washer but the metal plunger hits the contact. I'll just buy a reman starter and end this headache.
Old 02-12-2017, 02:42 PM   #26 (permalink)
Ram Year: 81 93
Engine: 5.2
Default
you might need to tighten the nut a bit more if the rubber washer is too thick. you could possibly try replacing the contact/plunger with a kit like i posted a link to on amazon. that is likely all the ones at the parts store get which is why the contact wear out so quick. all new parts are so cheaply made.
__________________
Old 02-13-2017, 09:36 AM   #27 (permalink)
Ram Year: 1991
Engine: 5.2 318 v8
Default
I think I'm better off with a reman since it's freezing and snowing out like everyday the old starter will be a pain to install and I don't even know if it will work or not.
Old 02-17-2017, 10:50 PM   #28 (permalink)
Ram Year: 1991
Engine: 5.2 318 v8
Default
Ok I finally put a reman starter in my truck and now when I turn the key the starter spins but doesn't engage the flywheel. Wtf
Old 02-17-2017, 11:02 PM   #29 (permalink)
Ram Year: 81 93
Engine: 5.2
Default
did you test the starter before putting it in? if you got the starter bolted in like it should be then it should be working properly. maybe the plunger in the rebuild starter is too short and not pushing the gear far enough out.
__________________
Old 02-17-2017, 11:03 PM   #30 (permalink)
Ram Year: 1991
Engine: 5.2 318 v8
Default
They tested the starter at auto zone when I bought it and it passed. This is just my luck lol.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
1991 ram 250 318 v8 overheating olgold Engine & Performance 29 02-25-2016 10:26 AM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
