Yoox_II
- May 26, 2013
- 300
- 26
- 1984
- 5.7L Hemi
I need to replace this wire as it burned through, disconnecting the alternator therefore killing the battery while I drive. It connects around the back of the alternator in a plastic housing plug type set up. If I was to buy new wire, what should I look for? Its black but also has a turquoise inner layer. So I'm not sure if that means that it's a ground or not.
Edit: I think it's the b+ terminal wire. What exactly should I ask for in an auto parts store, is that the correct name for it?
