1985 Lowering Questions.
Garrett 1985
Slant Six 225 2.8L
I have a 1985 Dodge D100 Custom with a 225 Slant Six with a 3 Speed Automatic. Truck has no rust @ ALL! and its completely stock besides the rims. But besides all that I really want to lower my truck in the back and front. Im looking to get a 4" - 7" drop on front and back(Leveled out of course). If that is not possible without doing major amount of work I would love to just level the truck out and get rid of the ugly rake in the back. Please can someone just leave some info on how to lower an 85 or what i will need / have to do to achieve a lowered truck.
Now I notice that the 1985 Dodge came with the axle under the leaf so you cannot use lowering blocks which is what i wanted to do but the only way i can do that is to flip the axle but Im sure that will give me a big enough drop lol.
For the front i heard you can use Van lower control arms and it make the spring sit lower giving you a couple inches but is there another way because it seems hard to find those where I live
One question I have is that if i flip my rear axle will the pumpkin hit the bed?
Another question is what are the steps to flipping your axle.
Here are some pictures of my truck.
(The tag is colored in.)
https://puu.sh/w6Rar/34f4c8e333.png (Side / Passenger Side)
https://puu.sh/w6RnV/85d944fdb4.png (Front)
https://puu.sh/w6S8i/31609a378e.png (Another Front)
https://puu.sh/w6RI4/8ec38b862f.png (Side / Driver Side)
https://puu.sh/w6RMi/bc0850a859.png (Rear Axle)
https://puu.sh/w6RXD/9359a6ed20.png (Engine Bay)
Midnight 4x4
Houston Texas
2014 and 1984
5.7 and a slant six
Sounds like we have the same truck I’m in the same boat as you. I put lowering shackles on the rear and they leveled it. That is not low enough I’m going to be trying the van lower control arm route this weekend and see how that goes. I will inform you on my struggles as they approach.
vdubee
5.2L
What shackles did you use?
crazzywolfie
under the truck
GLHS592 who has an account on a couple different forums has lowered his and it came out looking pretty good but it but definitely looks like a bit of work. i know his post wont make a ton of sense with the photos missing but you can than photobucket for screwing them up. you can check out his photos here to
1980 Dodge D-150 by Kevin Isenberg | Photobucket
I forgot I was a member here. Here is a how-to I wrote up for the van lower control arms and the rear axle flip.
Nobody makes much in the way of aftermarket parts for 1972-1993 Dodge trucks. Parts for lowering your Dodge pickup are not offered by the major aftermarket companies like Belltech or Eibach. There is one small manufacturer that makes some very expensive lower control arms, but I've had no luck getting in contact with them. What can you do if you want to lower your pickup? You can go the cheap route by cutting your coil springs. This may cause your spring rates to change or cause camber problems. You could go the expensive route by modifying a pair of lowering spindles made for a 1st generation Dakota. I've heard this works, but there are a few issues with this and it takes a lot of trouble to get them to work.
There is another option that is very simple, engineered by the factory, and is cost effective. Go to the junkyard and find a 1972-1993 Dodge B-series van and unbolt the lower control arms. Just swapping the van's lower control arms onto your 1972-1993 Dodge half ton truck lowers it roughly 3" due to the fact that the van lower control arms have a spring pocket that allows the coil springs to sit lower than they do in the truck's stock lower control arms. No shock or spring change is needed. It doesn't matter if it is a 1/2 ton, 3/4 ton, or 1 ton van. The van lower control arms are the same. I purchased a pair from a mid 80's B350 for $40 plus tax at my local Pull-A-Part.
I had trouble separating the steering knuckle from the lower control arm at the ball joint. In fact, I gave up and left the junkyard. I asked around and found out that the steering knuckle is a two-piece design. There are two 15/16 bolts/nuts that you will have to unbolt in order to separate the top piece from the bottom piece. You will have to take the brake caliper and rotor off to gain access to the bolts. Remove those steering knuckle bolts, take out the shock absorber, unbolt the control arm pivot bolt, remove the strut rod from the lower control arms, and separate the steering tie rod from the lower steering knuckle piece and you're done. The only parts you will need are the lower control arms and the control arm pivot bolts/nuts. Once you get the lower control arms home, take a large hammer and remove the lower steering knuckle piece from the ball joint and then knock the ball joint out. You cannot reuse the ball joints from the one ton van because they are larger in diameter than the ones on your truck. I do not know if the 1/2 ton or 3/4 ton ball joints are the same or not. New ball joints are $30 at NAPA, so you might as well replace them anyway.
There are a couple modifications you will need to make to the lower control arms and your truck. First, completely remove the steering stops. They are not needed and the arms will look cleaner without them. Next, you will need to drill two 1/2" holes in each arm for the strut rods. I pulled a stringline from the center of the ball joint to the center of the pivot bushing and found the holes in the truck arms are equal distance from the centerline of the arm. Measure the distance from the ball joint to the strut rod holes on the truck arms. Now, you can transfer this information onto the van arms, mark your holes, and drill. There is one modification you will need to make to the lower control arm pivot holes on your truck's frame. The truck's factory lower control arm bolts are 5/8" in diameter. The van's are 3/4" in diameter. You will need to drill these holes larger for the van's bolts to fit the truck. I was thinking that maybe I would be able to slide the sleeve from the truck arms into the sleeve on the van arms so I wouldn't have to drill the pivot holes. The truck sleeve is too large in diameter to fit inside the van's sleeve,so that will not work. From this point, you may be able to just bolt the van arms on your truck. I had a little problem with mine. I tried to install my driver's side arm and the holes wouldn't begin to line up. I found that the metal around the pivot bushing on the arm was up against the pivot bracket on the truck. Before you paint your lower control arms, you may want to grind a little off the arms around the pivot bushing.
When I put the wheels back on and dropped the truck onto the ground, I measured 1/2" between the bottom of the fender and top of the tire. Before the drop, I measured 3.5". I'm very pleased with that. To my surprise, the camber wasn't off too bad, however, the wheels were pointed in different directions. I also had to cut the bump stop brackets off because they were hitting the lower control arms. Another thing, any time you perform work like this to your vehicle, a front end alignment is necessary.
The steering knuckle is a two piece design on the truck and van. You will need a 15/16" socket for these.
Van arms with van lower steering knuckle
Van arms with bump stops and ball joint removed
Side by side comparison of the truck arm and van arm. Blue arrows point to the strut rod bolt holes that you need to drill.
Truck pivot bolt (5/8") on top and van pivot bolt (3/4") on bottom
Drilling the truck's pivot bolt bracket from 5/8" to 3/4"
Grind in the unpainted area shown by the arrows. The holes in the lower control arms would not line up with the ones on the truck's pivot bracket due to this area touching the pivot bracket.
Finished product
Before
After
Rear axle flip:
I found a pair of leaf spring perches on an old rearend I had. I unbolted the axle and dropped it to the floor. I removed the shocks and dropped the driveshaft to make it easier to move the axle around. You may not have to do either. Then, I clamped the leaf springs together with a C-clamp before I removed the leaf centering pin to flip it over. You will have to remove each leaf spring from their hangers and put them under the axle. Sit the spring perches on top of each leaf spring and sit the axle on top of the spring perches. The new spring perches should be on the exact opposite side of the axle from the original spring perches to keep pinion angle. Clamp everything down using your original lower shock mount plates (modified in the picture below) and new U-bolts. Weld the rear axle to the spring perches.
Completed pictures.
Midnight 4x4
Houston Texas
2014 and 1984
5.7 and a slant six
I used the cheap ones drone oreillys there were like 40 bucks. Had a hard time getting the bolts out cause they probably had never been jacked with before. Also installed van lower control arms and its super easy to do don’t let them fool you don’t go to pull a part for the control arms. Rock auto has brand new LCA with ball joint and bushing for less than $40 each. Look for a 80’s 3/4 dodge van.
Midnight 4x4
Houston Texas
2014 and 1984
5.7 and a slant six
shackles are for a chevy a little wider than ours just ground them down to fit in the mount. It leveled the truck out kinda. Not low enough for me. LCA on the front just complete. Have to drill 2 - 1/2” holes by ball joint to match strut arm. I’m not sure if it is a steering stop but cut it off to clear the strut arm. Then have to trim a little metal off around the bushing so it doesn’t bind with the mount (also won’t fit you don’t). Then reinstall shocks and springs. Game over I got off work at 3 finish a 6 pretty easy to do.
Wesd100
Texas
Has anyone tried these Drop Spindles from X2industries?
wondering about quality?
1978-1993 Dodge Ram, Charger, Trailduster 2" Drop Spindles
[DG7893DRM2]
Your Price: $373.95
www.x2industries.com
1-800-823-0320
instructions:
-NEED TO USE 84 ROTORS(PART #5315) TO MAINTAIN 5450 BOLT PATTERN
-FLIP TIE RODS
-REQUIRES LARGER INNER BEARING ON 83 AND DOWN CODE11
-REVERSE TAP OF Ball Joint FOR MORE CLEARANCE
Wesd100
Texas
has anyone used the: " SHA-DO7893 Shackle Drop/Zerks Old Ram "
from airbagit.com?
is there any modification needed like for the chevy drop shackles?
VLG6963
