Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 1st Gen : 1981 - 1993 > Suspension
Suspension
'86 B350 ball joints
This is a discussion on '86 B350 ball joints within the Suspension forums, part of the 1st Gen : 1981 - 1993 category!
hello everybody! I am new here and I am writing in representation of my friend who recently bought '86 Dodge ...
Reply
Old 05-14-2014, 01:24 PM   #1 (permalink)
Ram Year: 1986
Engine: 5.9
Question '86 B350 ball joints
hello everybody!
I am new here and I am writing in representation of my friend who recently bought '86 Dodge Ram B350 5.9 V8 (photo) and does not speak english (we are located in Europe).
His current problem is choosing the right ball joints for his vehicle. Which should he use? There are many available with ratings 3600lbs and 4000lbs for H/D suspensions.
I found some sticker on his B350 saying:
GVWR 8510 LB
GAWR FRONT 3360 LB
GAWR REAR 5340 LB
This said, I don't see either 3600LB or 4000LB.
Thank you for any suggestions and help! Have a nice day.
Xaver.
P.S.: Oh, the vehicle does not have dual wheels in the rear.
Sponsored Ad
Register to remove this ad.
xaver is offline   Reply With Quote
Old 10-30-2014, 06:01 PM   #2 (permalink)
Redtruck-VA's Avatar
Ram Year: 2003 & 1989 D250 RWD
Engine: Hemi-5.7, 5.9 12v & 24v diesel
Default
I'm new to early dodges myself and changing ball joints on my 89 D250. I would recommend doing research and getting a good feel for the job. The problem apparently someone had with mine previously was they stripped the threads of the ball joint in the upper control arm. I would say use some penetrating oil and take your time in removing them. Good luck.
__________________
Greg 2003 SXT-Hemi SuperCharged, OCP manifold, billet CR 20" wheels, AeroForce gage, AFR, fuel Pressure, 46RH trans, Edge 3000, PPP Track Warrior, Shiftlite, TCI ProShifter, 180 stat, all aluminum radiator, HD Trans Cooler, DTT 4:10, LT's, Magnaflow duals cats, Mcgaughys 3/6 spindle kit, Monroe shocks, Caltracs, Aeon bumps, Roll Pan, shaved Ant, tail gate and cowl. And a 2007 QC manual trans/4wd diesel for a support vehicle.
Redtruck-VA is offline   Reply With Quote
Old 10-31-2014, 09:01 PM   #3 (permalink)
Default
Not to hijack this thread but to share some information. The ball joints are threaded into the upper control arms, but here's the kicker. The Upper control arms are not threaded. The ball joints require a specialized socket and the ball joints are self threading. It's no wonder that they are often damaged during installation and/or removal. I have a updated new upper control arm with the reinforcement. I can post up pictures tomorrow if anyone is interested. To do the job the parts I have ordered are the control arm, bushings, ball joint, knuckle, bottom ball joint and install tool.
__________________
Old 07-15-2016, 05:10 PM   #4 (permalink)
Bear79's Avatar
Ram Year: 02
Engine: Cummins
Default
Look at what is available from Moog. Check this links out: http://http://www.aftermarketsuspens...wer+Ball+Joint and http://http://www.aftermarketsuspens...per+Ball+Joint
Be sure to look at the notes to insure you get the correct ball joints.
Bear79 is offline   Reply With Quote
Reply
Bookmarks
Tags
1st gen ball joints, which ball joints
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Ball joints biker50610 General Discussion 0 05-08-2014 02:19 PM
Getting out the own ball joints. Help MoparSickness77 General Discussions 6 04-27-2012 01:10 AM
Ball Joints OlDirtyJohn Lifted 31 11-09-2011 09:00 AM
Ball Joints iSlacker816 2nd Gen DIY 2 11-02-2011 11:17 PM
ball joints bigtigga84 Tech Info 20 02-10-2011 03:56 AM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
