LED Signal lights (front)
Yoox_II
On fourth gen rams, the orange signal lights on the front beneath the headlamps are very intense and bright, and fill out the entire orange plastic light cover, so I am assuming they're LED's. If I install LED bulbs properly as front signal lights on my 84 dodge, will they be as bright as the 4th gen ram signal lights? Or will the orange light cover disperse the light too much? I could fabricate a replacement plastic orange cover with less angled sections to make for a more intense light from the LED's, but I'd rather not if I don't have to.
crazzywolfie
under the truck
there is more to installing led's in the front than the covers. the wiring on these trucks are a bit finicky. i think if you install a led in the front the turn signal indicator will stay on when you turn the marker lights on because the way things are wired and the way led lights work.
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
What about getting an electronic flasher? I've considered getting one for the 76 because my blinkers are somewhat erratic. lol
crazzywolfie
under the truck
electronic flasher would not solve this issue. all an electronic flasher would do is make the lights flash at a consistent speed even with the lack of load that led lights usually have.
that4wdwagon
Slant 6
I'm not sure on specifics and this is just a guess, but wouldn't you have to wire in some type of relay for them to work?
crazzywolfie
under the truck
a relay would not solve the issue. you would need bulbs with separate led's for the marker light and separate led's for the turn signal or the turn signal indicator would be on every time you turn the marker lights. some diodes might also solve the issue but i am not sure
