light trouble
harley41
b150
hello folks, I just bought a 91 B150 with only 42k miles,,,clean van, but the headlights taillights and parking lights and brake lights do not work. Fuse is good... Flashers and turn signals do work,,,any idea's on whats happening here? appreciate any input. Thanks...and happy Labor Day.
D350_LE
I would check to make sure the socket for the headlight switch hasn't melted. If it's good I'm pritty sure you should have two positive wires running to the switch if you have voltage at that point use an ohm meter to test the switch while it's out. It's been a while since I had to work on the lights on my truck but if I remember correctly all that runs through the headlight switch. Turn signals do not because it's on the columb. The taillights in mine had 6 applied with lights on and 12v when brakes were applied hence making them brighter. I'm not sure where the brights switch is on your van but it's on the floor in My 87 Ram. Make sure you don't have a bad connection there. If memory's serves me correctly a loose wire at that point had caused problems for me before.
MADDOG
Out Exploring Arizona
Also make sure those connections to each light bucket haven't corroded.
D350_LE
Yep those corroded grounds and brittle wires have been an issue as well.lol
