Rockstar Rims on First Gen 2WD
Yoox_II
I am looking to purchase a set of four black rockstar XD rims for my 84 D150. Tires included. Yes I realize this is pricey.
The only issue is the lugs. I have a 5 lug pattern, 113mm diameter. These rockstar rims seem to come in an 8 bolt patter, not sure what diameter size...
Will there be a lug adaptor/converter that will be the proper size to convert from 113mm to (whatever the rockstar rim is) or do you think I will have to get one made? I guess they assume that only people with 4wd trucks will be buying those rims so that's why this may be a challenge. I have the time and money to make this work though. I just want your guys' thoughts.
Thanks
quietpeen
2021 TRX
Hellcat
they make rockstars in 5 lug bolt pattern.
Stangshcky12
Oshkosh, WI
5.9 Cummins
I believe your bolt pattern is is 5x4.5" which is an available bolt pattern for that wheel
I'm sure you could find an adapter to go to what ever you want but its safer and probably cheaper just to buy the wheel with the right bolt pattern
Stangshcky12
Oshkosh, WI
5.9 Cummins
this site seems to have all the different part numbers for all the rockstars and includes bolt patterns, offsets, etc.
you can find the part number for the size wheel and color your looking for here
http://xdrockstarwheels.com/
Y
Yoox_II
That site is really helpful, thank you!
But I was trying to measure the distance between the lugs on my rim and it looked like it was 4 and a quarter inches apart, not 4.5....
When finding the bolt pattern size don't you have to multiply it by 1.05?
crazzywolfie
under the truck
you have to measure form the center of one lug to the center of the one across from it. you should get 4.5" or 5.5"
Y
Yoox_II
That's what I did, but I thought there was another step required. Multiply it by 1.05. That's what a how to article said that I read yesterday, anyway. Mine is 4.5 then if I don't have to multiply it.
