Tire size help needed..!
Magnum5.9
01 ram 1500 4x4
Magnum 5.9
Looking to go from 285/75/16 to 275/60/20 or 305/55/20 or 275/65/20 but am concerned I may run into rubbing issues while at full suspension articulation if I don't get the offset/backspace just right. I have a 01 4x4 with 2" spacer with new coils and shocks in the front and stock setup in the rear
Can anyone tell me what the biggest tire is that will not run with a 20" rims? I've searched around the sight but can't find too much info on a situation like mine. Thanks!
M
Magnum5.9
01 ram 1500 4x4
Magnum 5.9
No thoughts?
M
Magnum5.9
01 ram 1500 4x4
Magnum 5.9
As far as tires I am looking at Duatrac in load range C with those 20" rims. Or should I get with E?
jknappen
Kentucky
I run cooper discoverer st maxx 275/65/20. E load range. No rubbing. I have a 2013
crazzywolfie
under the truck
you might have got more responses if you posted in the right section. it looks like you have a 2nd gen and you posted in the 1st gen section
radikio
