Tires
lolorcaust
lolorcaust
TN
I did find a good deal on a 3" body lift, but 3" doesn't make a big enough difference for me. I don't know if I'd just have to buy extra leaf springs and or blocks or if I'd have to buy more to get it to a 4" or 6" lift.
LB3711
Trumbull, CT
3.6L V6
nice 1st gen. My GF had an 89 D150. I wish it was still around
glass3222
Central PA
3" body should clear 32"s with no problem, maybe 33" with minor rubbing. If you so a suspension lift, make sure you use new leafs in the front. Do NOT use blocks in the front. Blocks in the rear are ok, but in the front they are very unsafe. Add-a-leafs are ok as well, they just make it ride stiffer.
