thjeep
So I am trying to get my dad's 83 fixed.
He's getting way up there in years and I wanted to get some things on the truck he bought knew put back together while he can still enjoy it.
The truck has a little over 215,000 on the half ton with the 318 and is still in pretty good shape.
This started with a gas gauge that wouldn't work.
Replaced the sending unit in the tank and the voltage regulator on the back of the instrument panel.
Checked to make sure that the gauges work by grounding so that they all peg and work. They do.
Took out the gauges and cleaned the circuit board contacts and remounted and checked the ground and everything shows good.
The problem... you start it, the gauges peg and after a couple of minutes they all stop working.
I've had my mechanic helping me with this and he is a good wrench and even knows how to rebuild a carb but we are both lost and out of ideas here.
I know that I'm missing something but I don't know what.
If any of you have any experience with this or any ideas I would really appreciate the help.
thanks
thanks
