need help identifying this light
dwysywd
Metro Detroit MI
1983 D350 CCSB
360ci
So,I bought this cool old school wood grain dash. It has this spot in the top for a light... can not find the darn light on any website... any help?
sorry for the pdf, but i had trouble saving it as a jpg
Jeff
  • dash help needed.pdf
crazzywolfie
under the truck
not a very common option in most trucks. the ones i have seen are usually *****'d from what looks like heat damage. i think if you want something there you are best to build it yourself and use led lights
crazzywolfie
under the truck
all filament bulbs get hot which is why i like led lights. i also like the white light that led's usually put out especially when installed in the right spot
Redtruck-VA
Virginia
2003 & 1989 D250 RWD
That's called a map light, mine is broken also. ;(
dwysywd
dwysywd
Metro Detroit MI
1983 D350 CCSB
360ci
Mi had a feeling it was a map light hole! So, I likes the led idear. Any better pics of what you put in?
dwysywd
dwysywd
Metro Detroit MI
1983 D350 CCSB
360ci
RonJon,
Yours pictures are all duplicating them selves or you posted them 2x ea.
Sent from my bag phone...
Blue Chaos
Bloomington, IN
LA 318
Mine has one as well that works and I looove it. Adds a lot more light to the cab, I don't know why they ever stopped putting them in
crazzywolfie
under the truck
they lost the battle to overhead lighting. you can't beat the light output from overhead lighting.
crazzywolfie
under the truck
no the cab light at the back of the cab suck in comparison to like in a overhead console light up by the windshield like the picture i posted. i installed a overhead console in my ramcharger and the great light output from that got me wanting to put one in my 81 also mainly just for the better light.
Blue Chaos
Bloomington, IN
LA 318
But the cab light and map light together dominate overhead lights. Overhead lights cause a floorboard shadow. The cab and map light together don't and illuminate the whole cab very well. Especially with LED's in them
crazzywolfie
under the truck
i find the overhead light with led's lights up everything nearly perfectly. also in the pic i posted only 1 of the lights in on. it was nearly impossible to get a pic of the cab with the other light on. also if you are worried about shadows you could add led strips along the bottom dash frame for extra floor lighting.
Blue Chaos
Bloomington, IN
LA 318
But if you already have the map and some, no reason to install overhead. Especially since 85's don't have headliners. Just put in LED's and no shadows and really well lit
crazzywolfie
under the truck
But who actually likes stock. I started working on a overhead console for my 81. Better lighting plus I will know the outside temp and possibly the direction I am going if the roof is not magnitized. Will be well worth it if I finish.
The War Wagon
da' 'BURGH
318 Magnum
My RC is the cheapie LE150. It ain't got one. :(
NeedHead
